Datasheet CA3280, CA3280A (Intersil) - 2
ПроизводительIntersil
ОписаниеDual, 9MHz, Operational Transconductance Amplifier (OTA)
Страниц / Страница10 / 2 — Absolute Maximum Ratings. Thermal Information. Operating Conditions. …
Формат / Размер файлаPDF / 664 Кб
Absolute Maximum Ratings. Thermal Information. Operating Conditions. Electrical Specifications. CA3280. CA3280A. PARAMETER. SYMBOL
Absolute Maximum Ratings Thermal Information Operating Conditions Electrical Specifications CA3280 CA3280A PARAMETER SYMBOL
21 предложений от 20 поставщиков
, SP Amp Transconductance Amplifier Dual ±15V/36V 16Pin CDIP
CA3280F3
1 282 ₽
CA3280F3
Harris
1 389 ₽
CA3280AF/3
Intersil
CA3280AE
Intersil
CA3280, CA3280A .
Supply Voltage (Between V+ and V-). .+36V Thermal Resistance (Typical, Note 1) JA (oC/W) JC (oC/W) Differential Input Voltage . 5V PDIP Package . 90 N/A Input Voltage Range . V+ to V- Maximum Junction Temperature (Plastic Package) . .150oC Input Current at ID = 0 . 100A Maximum Storage Temperature Range . -65oC to 150oC Amplifier Bias Current (IABC). 10mA Maximum Lead Temperature (Soldering 10s) . 300oC Output Short Circuit Duration (Note 2). Indefinite Linearizing Diode Bias Current, ID. 5mA Peak Input Current with Linearizing Diode. ID
Temperature Range CA3280 . 0oC to 70oC CA3280A . -55oC to 125oC Supply Voltage Range (Typ) . 2V to 15V CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. JA is measured with the component mounted on a low effective thermal conductivity test board in free air. See Tech Brief TB379 for details. 2. Short circuit may be applied to ground or to either supply.
For Equipment Design, at TA = 25oC, VSUPPLY= 15V, Unless Otherwise Specified
CA3280 CA3280A PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX MIN TYP MAX UNITS
Input Offset Voltage VIO IABC = 1mA - - 3 - - 0.5 mV IABC = 100A - 0.7 3 - 0.25 0.5 mV IABC = 10A - - 3 - - 0.5 mV IABC = 1mA to 10A, - 0.8 4 - 0.8 1.5 mV TA = Full Temp. Range Input Offset Voltage Drift |VIO| IABC = 1A to 1mA - 0.5 1 - 0.5 1 mV IABC = 100A, TA = Full - 5 - - 3 5 V/oC Temperature Range Amplifier Bias Voltage VABC IABC = 100A - 1.2 - - 1.2 - V Peak Output Voltage VOM+ IABC = 500A 12 13.7 - 12.5 13.7 - V VOM- 12 -14.3 - -13.3 -14.3 - V VOM+ IABC = 5A 12 13.9 - 12.5 13.9 - V VOM- 12 -14.5 - -13.5 -14.5 - V Common Mode Input Voltage VICR IABC = 100A -13 - 13 -13 - 13 V Range Noise Voltage eN IABC = 500A 10Hz - 20 - - 20 - nV/Hz 1kHz - 8 - - 8 - nV/Hz 10kHz - 7 - - 7 - nV/Hz Input Offset Current IIO IABC = 500A -Z 0.3 0.7 - 0.3 0.7 A Input Bias Current IIB IABC = 500A - 1.8 5 - 1.8 5 A IABC = 500A, TA = Full - 3 8 - 3 8 A Temperature Range FN1174 Rev 6.00 Page 2 of 10 May 2002
