Datasheet MAX9691, MAX9692, MAX9693 (Maxim) - 5
| Производитель | Maxim |
| Описание | Single/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable |
| Страниц / Страница | 12 / 5 — Single/Dual, Ultra-Fast, ECL-Output. Comparators with Latch Enable. … |
| Формат / Размер файла | PDF / 328 Кб |
Single/Dual, Ultra-Fast, ECL-Output. Comparators with Latch Enable. MAX9691/MAX9692/MAX9693
29 предложений от 19 поставщиков Микросхема Компаратор, MAXIM INTEGRATED PRODUCTS MAX9693ESE+ Analog Comparator, ECL O/P, High Speed, 2, 1.2ns, 9.5V to 10.5V, NSOIC, 16Pins |
| MAX9693ESE+ Maxim | 544 ₽ | |
| MAX9693ESE+ Maxim | от 554 ₽ | |
| MAX9693ESE+ Analog Devices | 1 256 ₽ | |
| MAX9693ESE+ Analog Devices | по запросу | |
Single/Dual, Ultra-Fast, ECL-Output Comparators with Latch Enable MAX9691/MAX9692/MAX9693 Typical Operating Characteristics (continued)
(VCC = +5V, VEE = -5.2V, RL = 50Ω to VT, VT = -2V, VOD = 10mV, TA = +25°C, unless otherwise noted.)
PROPAGATION DELAY 100MHz OUTPUT RESPONSE
MAX9691/3-11 MAX9691/3-12 VIN = 100mV V -1.0V OD = 10mV VIN 200mV/div Q OUT 200mV/div -1.8V -1.0V Q OUT - Q OUT Q OUT 200mV/div 200mV/div -1.8V 1ns/div 1ns/div
Pin Description PIN MAX9692 MAX9692 NAME FUNCTION MAX9691 MAX9693 µMAX PDIP/SO
1 1 2 11 VCC Positive Supply. Bypass to GND with a 0.1µF capacitor. 2 2 3 — IN+ Positive Input 3 3 4 — IN- Negative Input 4 6 8 6 VEE Negative Supply. Bypass to GND with a 0.1µF capacitor. 5 7 11 — Q OUT Output 6 8 12 — Q OUT Complimentary Output 7 9 16 — GND2 Device Ground 8 10 1 — GND1 Device Ground 5, 7, 9, 10, — 4 — N.C. No Connection. Not internally connected. 13, 14, 15 — 5 6 — LE Latch Enable Input — — — 1 Q OUTA Channel A Output — — — 2 Q OUTA Channel A Complementary Output — — — 3, 14 GND Device Ground — — — 4 LEA Channel A Latch Enable Input — — — 5 LEA Channel A Latch Enable Complementary Input — — — 7 INA- Channel A Negative Input — — — 8 INA+ Channel A Positive Input — — — 9 INB+ Channel B Positive Input — — — 10 INB- Channel B Negative Input — — — 12 LEB Channel B Latch Enable Complementary Input — — — 13 LEB Channel B Latch Enable Input — — — 15 Q OUTB Channel B Complementary Output — — — 16 Q OUTB Channel B Output
_______________________________________________________________________________________ 5
