Datasheet DS2423 (Maxim) - 6
ПроизводительMaxim
Описание4kbit 1-Wire RAM with Counter
Страниц / Страница26 / 6 — Read Scratchpad Command [AAH]. Copy Scratchpad [5AH]. Not Recommended for …
Формат / Размер файлаPDF / 633 Кб
Read Scratchpad Command [AAH]. Copy Scratchpad [5AH]. Not Recommended for New Design
Read Scratchpad Command [AAH] Copy Scratchpad [5AH] Not Recommended for New Design
17 предложений от 16 поставщиков
Микросхема Чип RAM, NVRAM NVSRAM Serial-1Wire 4Kbit 3.3V/5V 6Pin TSOC
727GS
DS2423P
Maxim
от 36 ₽
DS2423P+
DS2423P+T&R
Maxim
DS2423P-500-00/T&R
Maxim
DS2423
This command is used to verify scratchpad data and target address. After issuing the Read Scratchpad command, the master begins reading. The first 2 bytes will be the target address. The next byte will be the ending offset/data status byte (E/S) followed by the scratchpad data beginning at the byte offset (T4: T0). The master may read data until the end of the scratchpad after which the data read will be all logic 1s.
This command is used to copy data from the scratchpad to memory. After issuing the Copy Scratchpad command, the master must provide a 3-byte authorization pattern which can be obtained by reading the scratchpad for verification. This pattern must exactly match the data contained in the three address registers (TA1, TA2, E/S, in that order). If the pattern matches, the AA (Authorization Accepted) flag will be set and the copy will begin. A pattern of alternating 1s and 0s will be transmitted after the data has been copied until a Reset Pulse is issued by the master. Any attempt to reset the part will be ignored while the copy is in progress. Copy typically takes 30µs. The data to be copied is determined by the three address registers. The scratchpad data from the beginning offset through the ending offset will be copied to memory, starting at the target address. Anywhere from 1 to 32 bytes may be copied to memory with this command. The AA flag will be cleared only by executing a Write Scratchpad command.
6 of 25
