Datasheet MTP3N60E (ON Semiconductor) - 3
ПроизводительON Semiconductor
ОписаниеTMOS E−FET High Energy Power FET N−Channel Enhancement−Mode Silicon Gate
Страниц / Страница9 / 3 — MTP3N60E. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. UNCLAMPED …
Формат / Размер файлаPDF / 292 Кб
MTP3N60E. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. UNCLAMPED DRAIN−TO−SOURCE AVALANCHE CHARACTERISTICS. THERMAL CHARACTERISTICS
MTP3N60E MAXIMUM RATINGS Rating Symbol Value Unit UNCLAMPED DRAIN−TO−SOURCE AVALANCHE CHARACTERISTICS THERMAL CHARACTERISTICS
6 предложений от 6 поставщиков
TMOS POWER FET 3.0 AMPERES 600 VOLTS RDS(on) = 2.2 OHMS
MTP3N60E
Motorola
48 ₽
MTP3N60E
Motorola
MTP3N60E
727GS
MTP3N60E
MTP3N60E
(TC = 25°C unless otherwise noted)
Drain−Source Voltage VDSS 600 Vdc Drain−Gate Voltage (RGS = 1.0 MΩ) VDGR 600 Vdc Gate−Source Voltage — Continuous VGS ± 20 Vdc Gate−Source Voltage — Non−repetitive VGSM ± 40 Vpk Drain Current — Continuous ID 3.0 Adc Drain Current — Continuous @ 100°C ID 2.4 Drain Current — Pulsed IDM 14 Total Power Dissipation @ TC = 25°C PD 75 Watts Derate above 25°C 0.6 W/°C Operating and Storage Temperature Range TJ, Tstg −55 to 150 °C
(TJ < 150°C) Single Pulse Drain−to−Source Avalanche Energy — TJ = 25°C WDSR(1) 290 mJ Single Pulse Drain−to−Source Avalanche Energy — TJ = 100°C 46 Repetitive Pulse Drain−to−Source Avalanche Energy WDSR(2) 7.5
Thermal Resistance — Junction to Case° RθJC 1.67 °C/W Thermal Resistance — Junction to Ambient° RθJA 62.5 Maximum Lead Temperature for Soldering Purposes, 1/8″ from case for 10 seconds TL 260 °C (1) VDD = 50 V, ID = 3.0 A (2) Pulse Width and frequency is limited by TJ(max) and thermal response
Designer’s Data for “Worst Case” Conditions
— The Designer’s Data Sheet permits the design of most circuits entirely from the information presented. SOA Limit curves — representing boundaries on device characteristics — are given to facilitate “worst case” design.
http://onsemi.com 2
