Datasheet ADG736 (Analog Devices) - 3
ОписаниеCMOS Low Voltage 2.5 Ω Dual SPDT Switch
Страниц / Страница12 / 3 — Data Sheet. ADG736. SPECIFICATIONS. Table 1. B Version. −40°C to. …
Формат / Размер файлаPDF / 249 Кб
Data Sheet. ADG736. SPECIFICATIONS. Table 1. B Version. −40°C to. Parameter. 25°C. +85°C. +125°C. Unit. Test Conditions/Comments
Data Sheet ADG736 SPECIFICATIONS Table 1 B Version −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
21 предложений от 19 поставщиков
ЧипСити
ADG736BRM-REEL
66 ₽
Hi-Tech Circuit Group
ADG736BRM-REEL7
ADG736BRM-REEL7
ADG736BRM-REEL7**PRI
link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 9 link to page 3
VDD = 5 V ± 10%, GND = 0 V. All specifications −40°C to +125°C, unless otherwise noted.
Table 1. B Version −40°C to −40°C to Parameter 25°C +85°C +125°C Unit Test Conditions/Comments
ANALOG SWITCH Analog Signal Range 0 V to VDD V On Resistance (RON) 2.5 Ω typ VS = 0 V to VDD, IDS = −10 mA; see Figure 10 4 4.5 7 Ω max On Resistance Match Between Channels (∆RON) 0.1 Ω typ VS = 0 V to VDD, IDS = −10 mA 0.4 0.4 Ω max On Resistance Flatness (RFLAT (ON)) 0.5 Ω typ VS = 0 V to VDD, IDS = −10 mA 1.2 1.5 Ω max LEAKAGE CURRENTS VDD = 5.5 V Source Off Leakage IS (Off) ±0.01 1 nA typ VS = 4.5 V/1 V, VD = 1 V/4.5 V; see Figure 11 Channel On Leakage ID, IS (On) ±0.01 5 nA typ VS = VD = 1 V or 4.5 V; see Figure 12 DIGITAL INPUTS Input High Voltage, VINH 2.4 2.4 V min Input Low Voltage, VINL 0.8 0.8 V max Input Current, IINL or IINH 0.005 µA typ VIN = VINL or VINH ± 0.1 ± 0.1 µA max DYNAMIC CHARACTERISTICS1 tON 12 ns typ RL = 300 Ω, CL = 35 pF 16 16 ns max VS = 3 V; see Figure 13 tOFF 5 ns typ RL = 300 Ω, CL = 35 pF 8 8 ns max VS = 3 V; see Figure 13 Break-Before-Make Time Delay, tD 7 ns typ RL = 300 Ω, CL = 35 pF 1 1 ns min VS1 = VS2 = 3 V; see Figure 14 Off Isolation –62 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz –82 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 15 Channel-to-Channel Crosstalk –62 dB typ RL = 50 Ω, CL = 5 pF, f = 10 MHz –82 dB typ RL = 50 Ω, CL = 5 pF, f = 1 MHz; see Figure 16 Bandwidth (–3 dB) 200 MHz typ RL = 50 Ω, CL = 5 pF; see Figure 17 CS (Off) 9 pF typ CD, CS (On) 32 pF typ POWER REQUIREMENTS VDD = 5.5 V IDD 0.001 µA typ Digital inputs = 0 V or 5 V 1.0 1.0 µA max 1 Guaranteed by design; not subject to production test. Rev. D | Page 3 of 12 Document Outline Features Applications Functional Block Diagram General Description Product Highlights Revision History Specifications Absolute Maximum Ratings ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Test Circuits Terminology Applications Information Outline Dimensions Ordering Guide Automotive Products
