Datasheet BM1Z102FJ, BM1Z103FJ (Rohm) - 6
| Производитель | Rohm |
| Описание | AC Voltage Zero Cross Detection IC |
| Страниц / Страница | 23 / 6 — BM1Z102FJ BM1Z103FJ. 1. AC Voltage Zero Cross Detection – continued. 1.2 … |
| Формат / Размер файла | PDF / 1.3 Мб |
BM1Z102FJ BM1Z103FJ. 1. AC Voltage Zero Cross Detection – continued. 1.2 VH_AC1 Pin UVLO
BM1Z102FJ BM1Z103FJ 1. AC Voltage Zero Cross Detection – continued 1.2 VH_AC1 Pin UVLO
In case that the peak voltage of the VH_AC1 pin is VACUVLO or less, the ACOUT pin voltage is defined as Hiz. VH_AC1 – GND VACUVLO Voltage 0 V HiZ ACOUT – GND Voltage Low Figure 5. VH_AC1 Pin UVLO
1.3 VH_AC1 and VH_AC2 Pins Noise Filter
This IC has two noise filters. Noise Filter 1 (tAC1): In case of the ACOUT pin voltage = Hiz, signals of pulse width < tAC1 is not accepted. <tAC1 VH_AC1 – GND Voltage VH_AC2 – GND Voltage 0 V HiZ ACOUT – GND Voltage Low Figure 6. VH_AC1 and VH_AC2 Pins Noise Filter 1 Noise Filter 2 (tAC2): In case of the ACOUT pin voltage = Low, signals of pulse width < tAC2 is not accepted. <tAC2 VH_AC1 – GND Voltage VH_AC2 – GND Voltage 0 V HiZ ACOUT – GND Voltage Low Figure 7. VH_AC1 and VH_AC2 Pins Noise Filter 2 www.rohm.com
TSZ02201-0F1F0A200610-1-2
© 2019 ROHM Co., Ltd. All rights reserved. 6/20 TSZ22111 • 15 • 001
12.Mar.2020 Rev.00 1
Document Outline General Description Features Applications Key Specifications Package Lineup Typical Application Circuit Pin Configuration Pin Descriptions Block Diagram Description of Blocks 1. AC Voltage Zero Cross Detection 1.1 Startup Sequence 1.2 VH_AC1 Pin UVLO 1.3 VH_AC1 and VH_AC2 Pins Noise Filter 1.4 DSET Pin Setting 2. DC Voltage Monitor Circuit Absolute Maximum Ratings Thermal Loss Recommended Operating Conditions Electrical Characteristics Typical Performance Curves I/O Equivalence Circuit Operational Notes 1. Reverse Connection of Power Supply 2. Power Supply Lines 3. Ground Voltage 4. Ground Wiring Pattern 5. Recommended Operating Conditions 6. Inrush Current 7. Testing on Application Boards 8. Inter-pin Short and Mounting Errors 9. Unused Input Pins 10. Regarding the Input Pin of the IC 11. Ceramic Capacitor 12. Thermal Shutdown Circuit (TSD) 13. Over Current Protection Circuit (OCP) Ordering Information Marking Diagram Physical Dimension and Packing Information Revision History
