Datasheet MBRS2040 (ON Semiconductor) - 2
ПроизводительON Semiconductor
ОписаниеSurface Mount Schottky Power Rectifier SMB Power Surface Mount Package
Страниц / Страница6 / 2 — MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN. MAXIMUM RATINGS. Rating. …
Формат / Размер файлаPDF / 310 Кб
MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN. MAXIMUM RATINGS. Rating. Symbol. Value. Unit. THERMAL CHARACTERISTICS. Characteristic
MBRS2040LT3G, NRVBS2040LT3G, NRVBS2040LN MAXIMUM RATINGS Rating Symbol Value Unit THERMAL CHARACTERISTICS Characteristic
16 предложений от 12 поставщиков
Выпрямитель Шоттки, 40 В, 2 А, Одиночный, DO-214AA, 2 вывод(-ов), 500 мВ
NRVBS2040LT3G-VF01
17 ₽
727GS
NRVBS2040LT3G
35 ₽
NRVBS2040LT3G
от 107 ₽
NRVBS2040LT3G
link to page 2 link to page 2 link to page 2 link to page 3 link to page 2 link to page 3
Peak Repetitive Reverse Voltage VRRM 40 V Working Peak Reverse Voltage VRWM DC Blocking Voltage VR Average Rectified Forward Current IO A (At Rated VR, TC = 103°C) 2.0 Peak Repetitive Forward Current IFRM A (At Rated VR, Square Wave, 20 kHz, TC = 104°C) 4.0 Non−Repetitive Peak Surge Current IFSM A (Surge Applied at Rated Load Conditions Halfwave, Single Phase, 60 Hz) 70 Storage Temperature Tstg, TC −55 to +150 °C Operating Junction Temperature TJ −55 to +125 °C Voltage Rate of Change dv/dt V/ms (Rated VR, TJ = 25°C) 10,000 Stresses exceeding those listed in the Maximum Ratings table may damage the device. If any of these limits are exceeded, device functionality should not be assumed, damage may occur and reliability may be affected.
THERMAL CHARACTERISTICS Characteristic Symbol Value Unit
Thermal Resistance — Junction−to−Lead (Note 1) RθJL 22.5 °C/W Thermal Resistance — Junction−to−Ambient (Note 2) RθJA 78 1. Minimum pad size (0.108 X 0.085 inch) for each lead on FR4 board. 2. 1 inch square pad size (1 x 0.5 inch for each lead) on FR4 board.
ELECTRICAL CHARACTERISTICS Characteristic Symbol Value Unit
Maximum Instantaneous Forward Voltage (Note 3) VF
TJ = 25
C TJ = 125
C
Volts see Figure 2 (I 0.43 0.34 F = 2.0 A) (I 0.50 0.45 F = 4.0 A) Maximum Instantaneous Reverse Current (Note 3) IR
TJ = 25
C TJ = 100
C
mA see Figure 4 (VR = 40 V) 0.8 20 (VR = 20 V) 0.1 6.0 Product parametric performance is indicated in the Electrical Characteristics for the listed test conditions, unless otherwise noted. Product performance may not be indicated by the Electrical Characteristics if operated under different conditions. 3. Pulse Test: Pulse Width ≤ 250 μs, Duty Cycle ≤ 2.0%.
www.onsemi.com 2
