Datasheet MC33023, MC34023 (ON Semiconductor) - 4
ПроизводительON Semiconductor
ОписаниеHigh Speed Single-Ended PWM Controller
Страниц / Страница19 / 4 — MC34023, MC33023. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. …
MC34023, MC33023. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Typ. Max. Unit. REFERENCE SECTION. OSCILLATOR SECTION
MC34023, MC33023 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Typ Max Unit REFERENCE SECTION OSCILLATOR SECTION
21 предложений от 20 поставщиков
Микросхема Контроллер PWM, Current Mode PWM Controller 500mA 1000kHz 16Pin PDIP Tube
MC34023PG
106 ₽
MC34023PG
188 ₽
MC34023PG
241 ₽
MC34023PG
link to page 4
(VCC = 15 V, RT = 3.65 kW, CT = 1.0 nF, for typical values TA = +25°C, for min/max values TA is the operating ambient temperature range that applies [Note 2], unless otherwise noted.)
Reference Output Voltage (IO = 1.0 mA, TJ = +25°C) Vref 5.05 5.1 5.15 V Line Regulation (VCC = 10 V to 30 V) Regline − 2.0 15 mV Load Regulation (IO = 1.0 mA to 10 mA) Regload − 2.0 15 mV Temperature Stability TS − 0.2 − mV/°C Total Output Variation over Line, Load, and Temperature Vref 4.95 − 5.25 V Output Noise Voltage (f = 10 Hz to 10 kHz, TJ = +25°C) Vn − 50 − mV Long Term Stability (TA = +125°C for 1000 Hours) S − 5.0 − mV Output Short Circuit Current ISC − 30 − 65 −100 mA
OSCILLATOR SECTION
Frequency kHz TJ = +25°C fosc 380 400 420 Line (VCC = 10 V to 30 V) and Temperature (TA = Tlow to Thigh) 370 400 430 Frequency Change with Voltage (VCC = 10 V to 30 V) Dfosc/DV − 0.2 1.0 % Frequency Change with Temperature (TA = Tlow to Thigh) Dfosc/DT − 2.0 − % Sawtooth Peak Voltage VOSC(P) 2.6 2.8 3.0 V Sawtooth Valley Voltage VOSC(V) 0.7 1.0 1.25 V Clock Output Voltage V High State VOH 3.9 4.5 − Low State VOL − 2.3 2.9
ERROR AMPLIFIER SECTION
Input Offset Voltage VIO − − 15 mV Input Bias Current IIB − 0.6 3.0 mA Input Offset Current IIO − 0.1 1.0 mA Open−Loop Voltage Gain (VO = 1.0 V to 4.0 V) AVOL 60 95 − dB Gain Bandwidth Product (TJ = +25°C) GBW 4.0 8.3 − MHz Common Mode Rejection Ratio (VCM = 1.5 V to 5.5 V) CMRR 75 95 − dB Power Supply Rejection Ratio (VCC = 10 V to 30 V) PSRR 85 110 − dB Output Current, Source (VO = 4.0 V) ISource 0.5 3.0 − mA Output Current, Sink (VO = 1.0 V) ISink 1.0 3.6 − Output Voltage Swing, High State (IO = −0.5 mA) VOH 4.5 4.75 5.0 V Output Voltage Swing, Low State (IO = 1 mA) VOL 0 0.4 1.0 Slew Rate SR 6.0 12 − V/ms
PWM COMPARATOR SECTION
Ramp Input Bias Current IIB − −0.5 −5.0 mA Duty Cycle, Maximum DC(max) 80 90 − % Duty Cycle, Minimum DC(min) − − 0 Zero Duty Cycle Threshold Voltage Pin 3(4) (Pin 7(9) = 0 V) Vth 1.1 1.25 1.4 V Propagation Delay (Ramp Input to Output, TJ = +25°C) tPLH(in/out) − 60 100 ns
SOFT−START SECTION
Charge Current (VSoft−Start = 0.5 V) Ichg 3.0 9.0 20 mA Discharge Current (VSoft−Start = 1.5 V) Idischg 1.0 4.0 − mA 1. Maximum package power dissipation limits must be observed. 2. Low duty cycle pulse techniques are used during test to maintain junction temperature as close to ambient as possible. Tlow = 0°C for MC34023 Thigh = +70°C for MC34023 = −40°C for MC33023 = +105°C for MC33023
http://onsemi.com 3
