Datasheet TPV803, TPV809, TPV810 (3PEAK) - 5
Производитель3PEAK
ОписаниеLow Voltage Supervisory Circuit
Страниц / Страница15 / 5 — TPV803/809/810. Low Voltage Supervisory Circuit. Specifications. Absolute …
Формат / Размер файлаPDF / 708 Кб
TPV803/809/810. Low Voltage Supervisory Circuit. Specifications. Absolute Maximum Ratings. Parameter. Min. Max. Unit. Note:
TPV803/809/810 Low Voltage Supervisory Circuit Specifications Absolute Maximum Ratings Parameter Min Max Unit Note:
32 предложений от 7 поставщиков
Усилители операционные, дифференциальные, инструментальные;SOT23
Microfind
TPV809S-3STR
3PEAK
2.77 ₽
ICdarom.ru
TPV809S-3STR
3PEAK
от 3.00 ₽
TPV809S-3STR
3PEAK
от 3.86 ₽
Зенер
Россия и страны ТС
TPV809S-3STR
от 5.60 ₽
Input Voltage VCC −0.3 6 V source or sink current for Push-pull, and sink Output Current 20 mA current for open drain of RESET/RESET TOP Operating Temperature −40 125 °C TJ Maximum Junction Temperature 150 °C TSTG Storage Temperature Range −65 150 °C TL Lead Temperature (Soldering 10 sec) 260 °C
Note:
Stresses beyond those listed under Absolute Maximum Ratings may cause permanent damage to the device. Exposure to any Absolute Maximum Rating condition for extended periods may affect device reliability and lifetime. (1) This data was taken with the JEDEC low effective thermal conductivity test board. (2) This data was taken with the JEDEC standard multilayer test boards.
ESD, Electrostatic Discharge Protection Symbol Parameter Condition Minimum Level Unit
HBM Human Body Model ESD ANSI/ESDA/JEDEC JS-001(1) 4000 V CDM Charged Device Model ESD ANSI/ESDA/JEDEC JS-002(2) 2000 V (1) JEDEC document JEP155 states that 500-V HBM allows safe manufacturing with a standard ESD control process. (2) JEDEC document JEP157 states that 250-V CDM allows safe manufacturing with a standard ESD control process.
www.3peakic.com.cn 5 / 15 Rev.A.5
