Datasheet MM74C00, MM74C02, MM74C04 (Fairchild) - 6
ПроизводительFairchild
ОписаниеQuad 2-Input NAND Gate Quad 2-Input NOR Gate Hex Inverter
Страниц / Страница6 / 6 — ter. Physical Dimensions. ver. x In e. • H. Gate. nput NOR. Quad 2-I • e. …
Формат / Размер файлаPDF / 92 Кб
ter. Physical Dimensions. ver. x In e. • H. Gate. nput NOR. Quad 2-I • e. Gat. NAND. Input
ter Physical Dimensions ver x In e • H Gate nput NOR Quad 2-I • e Gat NAND Input
Интегральные микросхемы Логические микросхемы - Затворы и Инверторы
MM74C00M
65 ₽
Зенер
Россия и страны ТС
MM74C00M
254 ₽
Hi-Tech Circuit Group
MM74C00M
Fairchild
SUV System
MM74C00M
inches (millimeters) unless otherwise noted (Continued)
ver x In e • H Gate nput NOR Quad 2-I • e Gat NAND Input 14-Lead Plastic Dual-In-Line Package (PDIP), JEDEC MS-001, 0.300” Wide Package Number N14A Quad 2- MM74C04 MM74C02 • • LIFE SUPPORT POLICY 74C00
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT
M
DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF THE PRESIDENT OF FAIRCHILD
M
SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems 2. A critical component in any component of a life support which, (a) are intended for surgical implant into the device or system whose failure to perform can be rea- body, or (b) support or sustain life, and (c) whose failure sonably expected to cause the failure of the life support to perform when properly used in accordance with device or system, or to affect its safety or effectiveness. instructions for use provided in the labeling, can be rea- sonably expected to result in a significant injury to the
www.fairchildsemi.com
user. Fairchild does not assume any responsibility for use of any circuitry described, no circuit patent licenses are implied and Fairchild reserves the right at any time without notice to change said circuitry and specifications.
