Datasheet BAS521 (Diodes) - 2
Производитель | Diodes |
Описание | High Voltage Switching Diode |
Страниц / Страница | 5 / 2 — BAS521. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal … |
Формат / Размер файла | PDF / 346 Кб |
Язык документа | английский |
BAS521. Maximum Ratings. Characteristic. Symbol. Value. Unit. Thermal Characteristics. Electrical Characteristics. Min. Max. Test Condition
76 предложений от 31 поставщиков Диоды - общего назначения, управление питанием, коммутация Switching 300V 250mA |
| BAS521
| 1.88 ₽ | |
| BAS521B Nexperia | от 3.50 ₽ | |
| BAS521,115 Nexperia | от 6.99 ₽ | |
| BAS521,135 NXP | по запросу | |
BAS521 Maximum Ratings
(@TA = +25°C, unless otherwise specified.)
Characteristic Symbol Value Unit
Repetitive Peak Reverse Voltage VRRM 300 V Working Peak Reverse Voltage DC Blocking Voltage VRWM 300 V Forward Current (Note 6) IF 250 mA Non-Repetitive Peak Forward Surge Current @ t = 1.0µs IFSM 4.5 A Repetitive Peak Forward Current (Note 6) IFRM 1 A
Thermal Characteristics Characteristic Symbol Value Unit
Power Dissipation (Note 6) PD 325 mW Thermal Resistance Junction to Ambient Air (Note 6) RθJA 385 °C/W Operating and Storage Temperature Range TJ, TSTG -65 to +150 °C
Characteristic Symbol Min Max Unit Test Condition
Reverse Breakdown Voltage (Note 7) V(BR)R 300 V IR = 100µA Forward Voltage VF 1.1 V IF = 100mA 50 nA VR = 5V Reverse Current (Note 7) IR 150 nA VR = 250V 100 µA VR = 250V, TJ = +150°C Total Capacitance CT 5 pF VR = 0, f = 1.0MHz Reverse Recovery Time trr 50 ns IF = IR = 30mA, Irr = 0.1 × IR, RL = 100Ω Notes: 6. Part mounted on FR-4 board with recommended pad layout, which can be found on our website at http://www.diodes.com. 7. Short duration pulse test used to minimize self-heating effect. BAS521 2 of 5 August 2019 Document number: DS32175 Rev. 6 - 2
www.diodes.com
© Diodes Incorporated Document Outline Mechanical Data Features Marking Information Package Outline Dimensions Suggested Pad Layout
