Datasheet NDS351AN (ON Semiconductor) - 3
ПроизводительON Semiconductor
ОписаниеN-Channel, Logic Level, PowerTrench MOSFET
Страниц / Страница6 / 3 — NDS351AN. Electrical Characteristics. Symbol. Parameter. Test Conditions. …
Формат / Размер файлаPDF / 450 Кб
NDS351AN. Electrical Characteristics. Symbol. Parameter. Test Conditions. Min. Typ. Max. Units. Off Characteristics. On Characteristics
NDS351AN Electrical Characteristics Symbol Parameter Test Conditions Min Typ Max Units Off Characteristics On Characteristics
43 предложений от 24 поставщиков
NDS351AN
34 ₽
TradeElectronics
NDS351AN_F094
Fairchild
ЗУМ-СМД
NDS351AN
ТаймЧипс
NDS351AN/351
Fairchild
T = 25°C unless otherwise noted A
BVDSS Drain–Source Breakdown Voltage VGS = 0 V, ID = 250 µA 30 V ∆BVDSS Breakdown Voltage Temperature ID = 250 µA,Referenced to 25°C 26 mV/°C ∆TJ Coefficient IDSS Zero Gate Voltage Drain Current VDS = 24 V, VGS = 0 V 1 µA VDS = 24 V, VGS = 0 V, TJ = 55°C 10 µA IGSS Gate–Body Leakage VGS = ±20 V, VDS = 0 V ±100 nA
On Characteristics (Note 2)
VGS(th) Gate Threshold Voltage VDS = VGS, ID = 250 µA 0.8 2.1 3 V ∆VGS(th) Gate Threshold Voltage ID = 250 µA,Referenced to 25°C –4 mV/°C ∆TJ Temperature Coefficient RDS(on) Static Drain–Source VGS = 10 V, ID = 1.4 A 92 160 mΩ On–Resistance VGS = 4.5 V, ID = 1.2 A 120 250 VGS = 10 V, ID = 1.4 A, TJ = 125°C 114 214 ID(on) On–State Drain Current VGS = 4.5V, VDS = 5 V 3.5 A gFS Forward Transconductance VDS = 5 V, ID = 1.4 A 4 S
Dynamic Characteristics
Ciss Input Capacitance 145 pF VDS = 15 V, V GS = 0 V, Coss Output Capacitance f = 1.0 MHz 35 pF Crss Reverse Transfer Capacitance 15 pF RG Gate Resistance VGS = 15 mV, f = 1.0 MHz 1.6 Ω
Switching Characteristics (Note 2)
td(on) Turn–On Delay Time V 3 6 ns DD = 15 V, ID = 1 A, t V r Turn–On Rise Time GS = 10 V, RGEN = 6 Ω 8 16 ns td(off) Turn–Off Delay Time 16 29 ns tf Turn–Off Fall Time 2 4 ns Qg Total Gate Charge V 1.3 1.8 nC DS = 15 V, ID = 1.4 A, Q VGS = 4.5 V gs Gate–Source Charge 0.5 nC Qgd Gate–Drain Charge 0.5 nC
Drain–Source Diode Characteristics and Maximum Ratings
IS Maximum Continuous Drain–Source Diode Forward Current 0.42 A VSD Drain–Source Diode Forward VGS = 0 V, IS = 0.42 A (Note 2) 0.8 1.2 V Voltage trr Diode Reverse Recovery Time IF = 1.4 A, diF/dt = 100 A/µs 11 nS Qrr Diode Reverse Recovery Charge 4 nC
Notes: 1.
Rθ is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting surface of JA the drain pins. Rθ is guaranteed by design while R is determined by the user's board design. JC θCA a) 250°C/W when mounted on a b) 270°C/W when mounted on a 0.02 in2 pad of 2 oz. copper. minimum pad. Scale 1 : 1 on letter size paper
2.
Pulse Test: Pulse Width ≤ 300 µs, Duty Cycle ≤ 2.0% www.onsemi.com 2
