Datasheet NCS2005 (ON Semiconductor) - 10
ПроизводительON Semiconductor
ОписаниеOperational Amplifier, Low Power, 8 MHz GBW, Rail-to-Rail Input-Output
Страниц / Страница11 / 10 — PACKAGE DIMENSIONS. TSOP−5. SCALE 2:1. NOTE 5. D 5X. DETAIL Z. …
Формат / Размер файлаPDF / 579 Кб
PACKAGE DIMENSIONS. TSOP−5. SCALE 2:1. NOTE 5. D 5X. DETAIL Z. MILLIMETERS. TOP VIEW. DIM. MIN. MAX. C SEATING. END VIEW. PLANE. SIDE VIEW. GENERIC
PACKAGE DIMENSIONS TSOP−5 SCALE 2:1 NOTE 5 D 5X DETAIL Z MILLIMETERS TOP VIEW DIM MIN MAX C SEATING END VIEW PLANE SIDE VIEW GENERIC
37 предложений от 12 поставщиков
NCS2005SN1T1G
26 ₽
Эиком
NCS2005SN1T1G
от 45 ₽
NCS2005SN1T1G
76 ₽
NCS2005SN1T1G
123 ₽
MECHANICAL CASE OUTLINE
CASE 483 5 ISSUE N 1 DATE 12 AUG 2020
SCALE 2:1
NOTES: 1. DIMENSIONING AND TOLERANCING PER ASME
NOTE 5
Y14.5M, 1994.
D 5X
2. CONTROLLING DIMENSION: MILLIMETERS. 0.20 C A B 3. MAXIMUM LEAD THICKNESS INCLUDES LEAD FINISH
2X
0.10 T THICKNESS. MINIMUM LEAD THICKNESS IS THE MINIMUM THICKNESS OF BASE MATERIAL.
M
4. DIMENSIONS A AND B DO NOT INCLUDE MOLD
5 4
FLASH, PROTRUSIONS, OR GATE BURRS. MOLD
2X
0.20 T
B S
FLASH, PROTRUSIONS, OR GATE BURRS SHALL NOT
1 2 3
EXCEED 0.15 PER SIDE. DIMENSION A.
K
5. OPTIONAL CONSTRUCTION: AN ADDITIONAL TRIMMED LEAD IS ALLOWED IN THIS LOCATION.
B G DETAIL Z
TRIMMED LEAD NOT TO EXTEND MORE THAN 0.2 FROM BODY.
A A MILLIMETERS TOP VIEW DIM MIN MAX A
2.85 3.15
B
1.35 1.65
DETAIL Z C
0.90 1.10
D
0.25 0.50
J G
0.95 BSC
C H
0.01 0.10 0.05
J
0.10 0.26
H K
0.20 0.60
C SEATING END VIEW PLANE M
0 10 _ _
SIDE VIEW S
2.50 3.00
GENERIC SOLDERING FOOTPRINT* MARKING DIAGRAM*
1.9 0.074 5 5 0.95 XXXAYWG XXX MG 0.037 G G 1 1
Analog Discrete/Logic
2.4 XXX = Specific Device Code XXX = Specific Device Code 0.094 A = Assembly Location M = Date Code Y = Year G = Pb−Free Package 1.0 W = Work Week 0.039 G = Pb−Free Package (Note: Microdot may be in either location) 0.7 *This information is generic. Please refer to 0.028 SCALE 10:1 ǒ mm Ǔ inches device data sheet for actual part marking. Pb−Free indicator, “G” or microdot “ G”, *For additional information on our Pb−Free strategy and soldering may or may not be present. details, please download the ON Semiconductor Soldering and Mounting Techniques Reference Manual, SOLDERRM/D.
DOCUMENT NUMBER: 98ARB18753C
Electronic versions are uncontrolled except when accessed directly from the Document Repository. Printed versions are uncontrolled except when stamped “CONTROLLED COPY” in red.
DESCRIPTION: TSOP−5 PAGE 1 OF 1
ON Semiconductor and are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor reserves the right to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. ON Semiconductor does not convey any license under its patent rights nor the rights of others. © Semiconductor Components Industries, LLC, 2018 www.onsemi.com
