Datasheet IRFP240 (Vishay) - 2
ПроизводительVishay
ОписаниеPower MOSFET
Страниц / Страница10 / 2 — IRFP240. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. MAX. UNIT. …
IRFP240. THERMAL RESISTANCE RATINGS PARAMETER SYMBOL. TYP. MAX. UNIT. SPECIFICATIONS. PARAMETER SYMBOL. TEST. CONDITIONS. MIN. Static
IRFP240 THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP MAX UNIT SPECIFICATIONS PARAMETER SYMBOL TEST CONDITIONS MIN Static
69 предложений от 27 поставщиков
N-канальный Полевой транзистор (Vds=200V, Id=20A@T=25C, Id=12A@T=100C, Rds=0.18 R, P=150W, -55 to +150C)
ICdarom.ru
IRFP240PBF
от 121 ₽
IRFP240PBF
от 340 ₽
ТаймЧипс
IRFP240PBF*IRTO247AC
SUV System
IRFP240PBF
IRFP240
www.vishay.com Vishay Siliconix
THERMAL RESISTANCE RATINGS PARAMETER SYMBOL TYP. MAX. UNIT
Maximum junction-to-ambient RthJA - 40 Case-to-sink, flat, greased surface RthCS 0.24 - °C/W Maximum junction-to-case (drain) RthJC - 0.83
SPECIFICATIONS
(TJ = 25 °C, unless otherwise noted)
PARAMETER SYMBOL TEST CONDITIONS MIN. TYP. MAX. UNIT Static
Drain-source breakdown voltage VDS VGS = 0 V, ID = 250 μA 200 - - V VDS temperature coefficient ΔVDS/TJ Reference to 25 °C, ID = 1 mA - 0.29 - V/°C Gate-source threshold voltage VGS(th) VDS = VGS, ID = 250 μA 2.0 - 4.0 V Gate-source leakage IGSS VGS = ± 20 V - - ± 100 nA VDS = 200 V, VGS = 0 V - - 25 Zero gate voltage drain current IDSS μA VDS = 160 V, VGS = 0 V, TJ = 125 °C - - 250 Drain-source on-state resistance RDS(on) VGS = 10 V ID = 12 A b - - 0.18 Ω Forward transconductance gfs VDS = 50 V, ID = 12 A b 6.9 - - S
Dynamic
Input capacitance Ciss V - 1300 - GS = 0 V, Output capacitance Coss VDS = 25 V, - 400 - pF f = 1.0 MHz, see fig. 5 Reverse transfer capacitance Crss - 130 - Total gate charge Qg - - 70 I Gate-source charge Qgs V D = 18 A, VDS = 160 V, GS = 10 V - - 13 nC see fig. 6 and 13 b Gate-drain charge Qgd - - 39 Turn-on delay time td(on) - 14 - VDD = 100 V, ID = 18 A, Rise time tr - 51 - Rg = 9.1 Ω, RD = 5.4 Ω, ns Turn-off delay time td(off) see fig. 10 b - 45 - Fall time tf - 36 - Internal drain inductance L D D Between lead, - 5.0 - 6 mm (0.25") from package and center of nH Internal source inductance L G S - 13 - die contact S
Drain-Source Body Diode Characteristics
Continuous source-drain diode current IS MOSFET symbol - - 20 D showing the integral reverse A Pulsed diode forward current a I G SM - - 80 p - n junction diode S Body diode voltage VSD TJ = 25 °C, IS = 20 A, VGS = 0 V b - - 2.0 V Body diode reverse recovery time trr - 300 610 ns TJ = 25 °C, IF = 18 A, dI/dt = 100 A/μs b Body diode reverse recovery charge Qrr - 3.4 7.1 μC Forward turn-on time ton Intrinsic turn-on time is negligible (turn-on is dominated by LS and LD)
Notes
a. Repetitive rating; pulse width limited by maximum junction temperature (see fig. 11) b. Pulse width ≤ 300 μs; duty cycle ≤ 2 % S22-0046, Rev. C, 24-Jan-2021
2
Document Number: 91210 For technical questions, contact: hvm@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
