Datasheet MBT3906DW1 (ON Semiconductor) - 2
ПроизводительON Semiconductor
ОписаниеDual General Purpose Transistor
Страниц / Страница9 / 2 — MBT3906DW1. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Max. …
Формат / Размер файлаPDF / 354 Кб
MBT3906DW1. ELECTRICAL CHARACTERISTICS. Characteristic. Symbol. Min. Max. Unit. OFF CHARACTERISTICS. ON CHARACTERISTICS
MBT3906DW1 ELECTRICAL CHARACTERISTICS Characteristic Symbol Min Max Unit OFF CHARACTERISTICS ON CHARACTERISTICS
TRANS 2PNP 40V 0.2A SC88. Bipolar (BJT) Transistor Array 2 PNP (Dual) 40V 200mA 250MHz 150mW Surface Mount SC-88/SC70-6/SOT-363. Transistors -...
MBT3906DW1T2G
4.91 ₽
Рутоника
MBT3906DW1T2G
MBT3906DW1T2G
MBT3906DW1T2G
link to page 2 link to page 2
(TA = 25°C unless otherwise noted)
Collector−Emitter Breakdown Voltage (Note 2) V(BR)CEO −40 − Vdc Collector−Base Breakdown Voltage V(BR)CBO −40 − Vdc Emitter−Base Breakdown Voltage V(BR)EBO −5.0 − Vdc Base Cutoff Current IBL − −50 nAdc Collector Cutoff Current ICEX − −50 nAdc
ON CHARACTERISTICS
(Note 2) DC Current Gain hFE − (IC = −0.1 mAdc, VCE = −1.0 Vdc) 60 − (IC = −1.0 mAdc, VCE = −1.0 Vdc) 80 − (IC = −10 mAdc, VCE = −1.0 Vdc) 100 300 (IC = −50 mAdc, VCE = −1.0 Vdc) 60 − (IC = −100 mAdc, VCE = −1.0 Vdc) 30 − Collector−Emitter Saturation Voltage VCE(sat) Vdc (IC = −10 mAdc, IB = −1.0 mAdc) − −0.25 (IC = −50 mAdc, IB = −5.0 mAdc) − −0.4 Base −Emitter Saturation Voltage VBE(sat) Vdc (IC = −10 mAdc, IB = −1.0 mAdc) −0.65 −0.85 (IC = −50 mAdc, IB = −5.0 mAdc) − −0.95
SMALL−SIGNAL CHARACTERISTICS
Current−Gain − Bandwidth Product fT 250 − MHz Output Capacitance Cobo − 4.5 pF Input Capacitance Cibo − 10.0 pF Input Impedance hie kW (VCE = −10 Vdc, IC = −1.0 mAdc, f = 1.0 kHz) 2.0 12 Voltage Feedback Ratio hre X 10−4 (VCE = −10 Vdc, IC = −1.0 mAdc, f = 1.0 kHz) 0.1 10 Small−Signal Current Gain hfe − (VCE = −10 Vdc, IC = −1.0 mAdc, f = 1.0 kHz) 100 400 Output Admittance hoe mmhos (VCE = −10 Vdc, IC = −1.0 mAdc, f = 1.0 kHz) 3.0 60 Noise Figure NF dB (VCE = −5.0 Vdc, IC = −100 mAdc, RS = 1.0 k W, f = 1.0 kHz) − 4.0
SWITCHING CHARACTERISTICS
Delay Time (VCC = −3.0 Vdc, VBE = 0.5 Vdc) td − 35 ns Rise Time (IC = −10 mAdc, IB1 = −1.0 mAdc) tr − 35 Storage Time (VCC = −3.0 Vdc, IC = −10 mAdc) ts − 225 ns Fall Time (IB1 = IB2 = −1.0 mAdc) tf − 75 2. Pulse Test: Pulse Width ≤ 300 ms; Duty Cycle ≤ 2.0%.
www.onsemi.com 2
