Datasheet DD311 (SiTI) - 7
ПроизводительSiTI
ОписаниеHigh Constant Current Led Driver
Страниц / Страница15 / 7 — SILICON TOUCH TECHNOLOGY INC. DD311. Constant-Current Output. (A). ) / R. …
Формат / Размер файлаPDF / 432 Кб
SILICON TOUCH TECHNOLOGY INC. DD311. Constant-Current Output. (A). ) / R. (ohm) = 100. LED. 100. ( Vbias. REXT. EXT. REF. bias. ILED. VREXT
SILICON TOUCH TECHNOLOGY INC DD311 Constant-Current Output (A) ) / R (ohm) = 100 LED 100 ( Vbias REXT EXT REF bias ILED VREXT
7 предложений от 7 поставщиков
HIGH CONSTANT CURRENT LED DRIVER
DD311AM
DD311
E-Switch
DD311 /SITI/
Tracopower
727GS
DD311
E-Switch
點晶科技股份有限公司
. 新竹市科學園區展業一路 9 號 7 樓之 1 9-7F-1, Prosperity RoadⅠ, Hsin-Chu, Taiwan, R.O.C.
DD311
Tel:886-3-5645656 Fax:886-3-5645626
Constant-current value is set by the reference current input. The output current will be 100 times the input current value produced by an external resistor between the REXT pin and the bias voltage or, alternatively, force the low bias voltage to REXT pin. Varying the resistor or the bias voltage value can adjust the current scale ranging up to 1A. Notice that the output current is a little increasing or decreasing until the device temperature and ambient temperature are balance. The output current value is calculated roughly by the following equation:
I (A)
V ) / R (ohm) = 100
I (A) LED
100
( Vbias REXT EXT REF V V LED bias I R REF EXT ILED DD311
1 2 3 4 5
VREXT EN
Output Current as a Function of REXT value 1100 1000 Vbias=36V 900 Vbias=24V 800 Vbias=18V 700 ) Vbias=12V 600 Vbias=5V (mA 500 LED I 400 300 200 100 0 100 1000 10000 100000 REXT (ohm)
HIGH CONSTANT CURRENT LED DRIVER Version:PRE.001
Page 6
