Datasheet 4PID-10, 4PID-50, 4PID-100, 4PID-200, 4PID-2000, 4PID-5000, 4PID-10000 (Senovol) - 2
ПроизводительSenovol
ОписаниеPhotoionization Detector (PID) Sensors
Страниц / Страница2 / 2 — Pin. Out. Details. Pin. 1. –. VCC. Pin. 2. –. GND. Pin. 3. –. VOUT. …
Формат / Размер файлаPDF / 600 Кб
Pin. Out. Details. Pin. 1. –. VCC. Pin. 2. –. GND. Pin. 3. –. VOUT. Product. Selection. Product. Measurement. Photon. Response. Part. Number. Resolution. Sensitivity
Pin Out Details Pin 1 – VCC Pin 2 – GND Pin 3 – VOUT Product Selection Product Measurement Photon Response Part Number Resolution Sensitivity
37 предложений от 16 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Устройства управления светодиодами
HVLED805TR
52 ₽
Зенер
Россия и страны ТС
HVLED805TR
от 53 ₽
HVLED805TR
111 ₽
HVLED805TR
Pin Out Details Pin 1 – VCC Pin 2 – GND Pin 3 – VOUT Product Selection Product Measurement Photon Response Part Number Resolution Sensitivity Name Range Energy Time 4PID-10 Pid-106S-0100 0 ~10 ppm 10.6 eV 1 ppb > 100 mV/ppm < 5 s 4PID-50 PID-106S-0500 0 ~ 50 ppm 10.6 eV 10 ppb > 20 mV/ppm < 5 s 4PID-100 PID-106S-1000 0 ~100 ppm 10.6 eV 25 ppb > 10 mV/ppm < 5 s 4PID-200 PID-106S-2000 0 ~ 200 ppm 10.6 eV 50 ppb > 5 mV/ppm < 5 s 4PID-2000 PID-106S-2001 0 ~ 2,000 ppm 10.6 eV 500 ppb > 0.5 mV/ppm < 5 s 4PID-5000 PID-106S-5001 0 ~ 5,000 ppm 10.6 eV 1,000 ppb > 0.2 mV/ppm < 5 s 4PID-10000 PID-106S-1002 0 ~ 10,000 ppm 10.6 eV 2,000 ppb > 0.1 mV/ppm < 5 s Note The performance data in this document is taken by applying isobutylene to the PID sensor using Senovol lab testers. The PID sensor may perform differently if gases other than isobutylene are used. Sensitivity Temperature Data Safety Note If the sensor is used in certain instruments for life critical applications, it is required to read the instrument user's guide carefully and comply with the calibration procedures by using the certified target calibration gas before each use. Failure to do so may cause serious injury and/or fatality. It is highly recommended for customers to validate the sensor performance using this document as a reference for their product designs or applications. info@senovol.com www.senovol.com
