Datasheet HCPL-7800A, HCPL-7800 (Broadcom) - 6
ПроизводительBroadcom
ОписаниеIsolation Amplifier
Страниц / Страница20 / 6 — HCPL-7800A/HCPL-7800. Insulation and Safety-Related Specifications. …
Формат / Размер файлаPDF / 829 Кб
HCPL-7800A/HCPL-7800. Insulation and Safety-Related Specifications. Parameter. Symbol. Value. Units. Conditions
HCPL-7800A/HCPL-7800 Insulation and Safety-Related Specifications Parameter Symbol Value Units Conditions
76 предложений от 35 поставщиков
Элрус
HCPL-7800A-500E
от 279 ₽
МосЧип
HCPL7800A000E
HCPL7800A
Avago Technologies
HCPL7800A#50Y
Data Sheet Isolation Amplifer
Minimum External Air Gap L(101) 7.4 mm Measured from input terminals to output terminals, (Clearance) shortest distance through air. Minimum External Tracking L(102) 8.0 mm Measured from input terminals to output terminals, (Creepage) shortest distance path along the body. Minimum Internal Plastic Gap 0.5 mm Through insulation distance conductor to conductor, (Internal Clearance) usually the straight line distance thickness between the emitter and the detector. Tracking Resistance CTI >175 V DIN IEC 112/VDE 0303 Part 1 (Comparative Tracking Index) Isolation Group III a Material Group (DIN VDE 0110, 1/89, Table 1)
Absolute Maximum Ratings Parameter Symbol Min. Max. Units Note
Storage Temperature TS –55 125 °C Operating Temperature TA –40 100 Supply Voltage VDD1, VDD2 0 5.5 V Steady-State Input Voltage VIN+, VIN– –2.0 VDD1 + 0.5 2-Second Transient Input Voltage –6.0 Output Voltage VOUT –0.5 VDD2 + 0.5
Recommended Operating Conditions Parameter Symbol Min. Max. Units Note
Ambient Operating Temperature TA –40 85 °C Supply Voltage VDD1, VDD2 4.5 5.5 V Input Voltage (accurate and linear) VIN+, VIN– –200 200 mV a Input Voltage (functional) VIN+, VIN– –2 2 V a. Broadcom recommends operation with VIN– = 0V (tied to GND1). Limiting VIN+ to 100 mV improves DC nonlinearity and nonlinearity drift. If VIN– is brought above VDD1 – 2V, an internal test mode may be activated. This test mode is for testing LED coupling and is not intended for customer use.
NOTE:
For the following tables, Typical values represent the mean value of all characterization units at the nominal operating conditions. Typical drift specifications are determined by calculating the rate of change of the specified parameter versus the drift parameter (at nominal operating conditions) for each characterization unit, and then averaging the individual unit rates. The corresponding drift figures are normalized to the nominal operating conditions and show how much drift occurs as the particular drift parameter is varied from its nominal value, with all other parameters held at their nominal operating values. Note that the typical drift specifications in the following tables may differ from the slopes of the mean curves shown in the corresponding figures. Broadcom AV02-0410EN 6 Document Outline Description Features Applications Functional Diagram Ordering Information Package Outline Drawings Standard DIP Package Gull Wing Surface Mount Option 300 Solder Reflow Profile Regulatory Information IEC/EN/DIN EN 60747-5-5 Insulation Characteristics Insulation and Safety-Related Specifications Absolute Maximum Ratings Recommended Operating Conditions DC Electrical Specifications AC Electrical Specifications Package Characteristics Application Information Power Supplies and Bypassing PC Board Layout Current Sensing Resistors Sense Resistor Connections Output Side Frequently Asked Questions about the HCPL-7800(A) Basics Sense Resistor and Input Filter Isolation and Insulation Accuracy Power Supplies and Start-Up Miscellaneous
