Datasheet LMP2015, LMP2016 (National Semiconductor) - 3
ПроизводительNational Semiconductor
ОписаниеSingle/Dual High Precision, Rail-to-Rail Output Operational Amplifier
Страниц / Страница16 / 3 — LMP2015 Single/LMP2016 Dual. Symbol. Parameter. Conditions. Min. Typ. …
Формат / Размер файлаPDF / 527 Кб
LMP2015 Single/LMP2016 Dual. Symbol. Parameter. Conditions. Min. Typ. Max. Units. 1.50. 2.7V AC Electrical Characteristics. Boldface
LMP2015 Single/LMP2016 Dual Symbol Parameter Conditions Min Typ Max Units 1.50 2.7V AC Electrical Characteristics Boldface
IC OPAMP GP 2 CIRCUIT 8SOIC. General Purpose Amplifier 2 Circuit Rail-to-Rail 8-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
LMP2016MAX/NOPB
120 ₽
Рутоника
LMP2016MAX/NOPB
LMP2016MAX/NOPB
LMP2016MAX/NOPB
link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4 link to page 4
(Note 5) (Note 4) (Note 5) A Open Loop Voltage Gain 130 VOL R = 10 kΩ 95 L
90
dB R = 2 kΩ 90 124 L
85
I Output Current Sourcing, V = 0V 5 12 O O V (diff) = ±0.5V
3
IN mA Sinking, V = 5V 5 18 O V (diff) = ±0.5V
3
IN I Supply Current per Channel 0.919 1.20 S mA
T = 25°C, V+ = 2.7V, V− = 0V, V = 1.35V, V = 1.35V, and A CM O R > 1 MΩ.
Boldface
limits apply at the temperature extremes. L
(Note 5) (Note 4) (Note 5) GBWP Gain Bandwidth Product 3 MHz SR Slew Rate 4 V/μs θ Phase Margin 60 Deg m G Gain Margin −14 m dB e Input Referred Voltage Noise 35 n nV/ i Input Referred Current Noise n pA/ e p-p Input Referred Voltage Noise n R = 100Ω, DC to 10 Hz 850 nV S PP t Input Overload Recovery Time 50 rec ms
5V DC Electrical Characteristics
Unless otherwise specified, all limits guaranteed for T = 25°C, V+ = 5V, A V− = 0V, V = 2.5V, V = 2.5V and R > 1 MΩ.
Boldface
limits apply at the temperature extremes. CM O L
(Note 5) (Note 4) (Note 5) V Input Offset Voltage 0.12 5 OS (LMP2015 only)
10
μV Input Offset Voltage 0.12 5 (LMP2016 only)
10
Offset Calibration Time 0.5 10 ms
12
TCV Input Offset Voltage 0.015 .05 OS μV/°C Long Term Offset Drift 0.006 μV/month Lifetime V Drift 2.5 OS μV I Input Current −3 IN pA I Input Offset Current 6 OS pA R Input Differential Resistance 9 IND MΩ CMRR Common Mode Rejection Ratio −0.3 ≤ V ≤ 3.2 100 130 CM dB 0 ≤ V ≤ 3.2
90
CM CMVR Input Common Mode Range CMRR ≥ 100 dB −0.3 3.2 dB CMRR ≥ 90 dB 0 3.2 PSRR Power Supply Rejection Ratio V+ – V− = 2.7V to 5V, V = 0V 95 120 CM dB
90
3 www.national.com Document Outline LMP2015 Single/LMP2016 Dual General Description Features Applications Connection Diagrams Ordering Information Absolute Maximum Ratings Operating Ratings 2.7V DC Electrical Characteristics 2.7V AC Electrical Characteristics 5V DC Electrical Characteristics 5V AC Electrical Characteristics Typical Performance Characteristics Application Information THE BENEFITS OF THE LMP2015/LMP2016'sNO 1/f NOISE OVERLOAD RECOVERY FIGURE 1. Overload Recovery Test NO EXTERNAL CAPACITORS REQUIRED MORE BENEFITS HOW THE LMP2015/LMP2016 WORK FIGURE 2. The Output of a Chopper Stabilized Op Amp (MAX432) FIGURE 3. The Output of the LMP2015/LMP2016 INPUT CURRENTS PRECISION STRAIN GAUGE AMPLIFIER FIGURE 4. Precision Strain Gauge Amplifier FIGURE 5. Composite Amplifier Configuration TABLE 1. Composite Amplifier Measured Performance FIGURE 6. Composite Amplifier Configuration FIGURE 7. AC Coupled ADC Driver LMP2015 AS AN ADC DRIVER FIGURE 8. DC Coupled ADC Driver Physical Dimensions
