Datasheet LT1176, LT1176-5 (Analog Devices) - 8
ОписаниеStep-Down Switching Regulator
Страниц / Страница8 / 8 — PACKAGE DESCRIPTION. SW Package. 20-Lead Plastic Small Outline (Wide .300 …
Формат / Размер файлаPDF / 145 Кб
PACKAGE DESCRIPTION. SW Package. 20-Lead Plastic Small Outline (Wide .300 Inch)
PACKAGE DESCRIPTION SW Package 20-Lead Plastic Small Outline (Wide .300 Inch)
14 предложений от 14 поставщиков
IC REG BCK FLYBCK ADJ 20SOIC. Buck, Flyback Switching Regulator IC Positive or Negative Adjustable 2.21V 1 Output 1.2A (Switch) 20-SOIC...
LT1176CSW#TRPBF
288 ₽
SUV System
LT1176CSW#TRPBF
727GS
LT1176CSW#TRPBF
ТаймЧипс
LT1176CSW-5#TRPBF
LT1176/LT1176-5
(Reference LTC DWG # 05-08-1620) .030 .005 .050 BSC .045 .005 TYP .496 – .512 (12.598 – 13.005) NOTE 4 N 20 19 18 17 16 15 14 13 12 11 N .420 .325 .005 MIN NOTE 3 .394 – .419 (10.007 – 10.643) 1 2 3 N/2 N/2 RECOMMENDED SOLDER PAD LAYOUT .291 – .299 1 2 3 4 5 6 7 8 9 10 (7.391 – 7.595) NOTE 4 .037 – .045 .093 – .104 .010 – .029 (0.940 – 1.143) ¥ 45∞ (2.362 – 2.642) (0.254 – 0.737) .005 (0.127) RAD MIN 0 – 8 TYP .050 (1.270) .004 – .012 .009 – .013 (0.229 – 0.330) NOTE 3 BSC (0.102 – 0.305) .016 – .050 .014 – .019 S20 (WIDE) 0502 (0.406 – 1.270) (0.356 – 0.482) NOTE: TYP INCHES 1. DIMENSIONS IN (MILLIMETERS) 2. DRAWING NOT TO SCALE 3. PIN 1 IDENT, NOTCH ON TOP AND CAVITIES ON THE BOTTOM OF PACKAGES ARE THE MANUFACTURING OPTIONS. THE PART MAY BE SUPPLIED WITH OR WITHOUT ANY OF THE OPTIONS 4. THESE DIMENSIONS DO NOT INCLUDE MOLD FLASH OR PROTRUSIONS. MOLD FLASH OR PROTRUSIONS SHALL NOT EXCEED .006" (0.15mm) 11765fb 8 Linear Technology Corporation LT 0211 REV B • PRINTED IN USA 1630 McCarthy Blvd., Milpitas, CA 95035-7417 (408) 432-1900 ● FAX: (408) 434-0507 ● www.linear.com LINEAR TECHNOLOGY CORPORATION 1993 Document Outline Features Applications Description Typical Application Absolute Maximum Ratings Pin Configuration Order Information Electrical Characteristics Block Diagram Package Description Revision History Package Description
