Datasheet MMSZ, SZMM (ON Semiconductor) - 2
ПроизводительON Semiconductor
ОписаниеZener Voltage Regulators
Страниц / Страница7 / 2 — MMSZxxxT1G Series, SZMMSZxxxT1G Series. ELECTRICAL CHARACTERISTICS. …
Формат / Размер файлаPDF / 282 Кб
MMSZxxxT1G Series, SZMMSZxxxT1G Series. ELECTRICAL CHARACTERISTICS. Symbol. Parameter. Zener Voltage Regulator. VZ1 (Volts). ZZT1
MMSZxxxT1G Series, SZMMSZxxxT1G Series ELECTRICAL CHARACTERISTICS Symbol Parameter Zener Voltage Regulator VZ1 (Volts) ZZT1
17 предложений от 10 поставщиков
Zener Diode 10 V 500 mW ±5% Surface Mount SOD-123
MMSZ10T3G
от 5.00 ₽
Эиком
MMSZ10T3G
от 5.30 ₽
SUV System
MMSZ10T3G
Hi-Tech Circuit Group
MMSZ10T3G
link to page 2 link to page 2 link to page 2 link to page 2 link to page 2 link to page 2
(TA = 25°C unless
I
otherwise noted, VF = 0.95 V Max. @ IF = 10 mA) IF
Symbol Parameter
VZ Reverse Zener Voltage @ IZT IZT Reverse Current ZZT Maximum Zener Impedance @ IZT VZ VR
V
I V I R F R Reverse Leakage Current @ VR IZT VR Reverse Voltage IF Forward Current VF Forward Voltage @ IF
Zener Voltage Regulator ELECTRICAL CHARACTERISTICS
(TA = 25°C unless otherwise noted, VF = 0.9 V Max. @ IF = 10 mA)
VZ1 (Volts) ZZT1 VZ2 (Volts) ZZT2 Max Reverse
(Notes 3 and 4) (Note 5) (Notes 3 and 4) (Note 5)
Leakage Current @ I Device ZT1 = 5 mA @ IZT2 = 1 mA IR @ VR Device* Marking Min Nom Max W Min Max W mA Volts
MMSZ2V4T1G T1 2.28 2.4 2.52 100 1.7 2.1 600 50 1 MMSZ2V7T1G T2 2.57 2.7 2.84 100 1.9 2.4 600 20 1 MMSZ3V0T1G T3 2.85 3.0 3.15 95 2.1 2.7 600 10 1 MMSZ3V3T1G T4 3.14 3.3 3.47 95 2.3 2.9 600 5 1 MMSZ3V6T1G T5 3.42 3.6 3.78 90 2.7 3.3 600 5 1 MMSZ3V9T1G U1 3.71 3.9 4.10 90 2.9 3.5 600 3 1 MMSZ4V3T1G U2 4.09 4.3 4.52 90 3.3 4.0 600 3 1 MMSZ4V7T1G U3 4.47 4.7 4.94 80 3.7 4.7 500 3 2
MMSZ5V1T1G U4 4.85 5.1 5.36 60 4.2 5.3 480 2 2 MMSZ5V6T1G/T3G U5 5.32 5.6 5.88 40 4.8 6.0 400 1 2 MMSZ6V2T1G V1 5.89 6.2 6.51 10 5.6 6.6 150 3 4
MMSZ6V8T1G V2 6.46 6.8 7.14 15 6.3 7.2 80 2 4 MMSZ7V5T1G V3 7.13 7.5 7.88 15 6.9 7.9 80 1 5 MMSZ8V2T1G V4 7.79 8.2 8.61 15 7.6 8.7 80 0.7 5 MMSZ9V1T1G V5 8.65 9.1 9.56 15 8.4 9.6 100 0.5 6 MMSZ10T1G/T3G A1 9.50 10 10.50 20 9.3 10.6 150 0.2 7 MMSZ11T1G A2 10.45 11 11.55 20 10.2 11.6 150 0.1 8 MMSZ12T1G A3 11.40 12 12.60 25 11.2 12.7 150 0.1 8 MMSZ13T1G A4 12.35 13 13.65 30 12.3 14.0 170 0.1 8 MMSZ15T1G A5 14.25 15 15.75 30 13.7 15.5 200 0.05 10.5 MMSZ16T1G X1 15.20 16 16.80 40 15.2 17.0 200 0.05 11.2
MMSZ18T1G/T3G X2 17.10 18 18.90 45 16.7 19.0 225 0.05 12.6
MMSZ20T1G X3 19.00 20 21.00 55 18.7 21.1 225 0.05 14 MMSZ22T1G X4 20.90 22 23.10 55 20.7 23.2 250 0.05 15.4 MMSZ24T1G X5 22.80 24 25.20 70 22.7 25.5 250 0.05 16.8 3. The type numbers shown have a standard tolerance of ±5% on the nominal Zener Voltage. 4. Tolerance and Voltage Designation: Zener Voltage (VZ) is measured with the Zener Current applied for PW = 1 ms. 5. ZZT and ZZK are measured by dividing the AC voltage drop across the device by the AC current applied. The specified limits are for IZ(AC) = 0.1 IZ(DC), with the AC frequency = 1 kHz. *Include SZ-prefix devices where applicable.
www.onsemi.com 2
