Datasheet VCNL36828P (Vishay) - 3
ПроизводительVishay
ОписаниеA Small Package Proximity Sensor With a VCSEL, Low Idle Current, I 2C Interface, and Smart Dual Slave Address
Страниц / Страница20 / 3 — VCNL36828P. BASIC CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. …
Формат / Размер файлаPDF / 287 Кб
VCNL36828P. BASIC CHARACTERISTICS. PARAMETER. TEST CONDITION. SYMBOL. MIN. TYP. MAX. UNIT. ASIC. VCSEL. PHOTODIODE. Notes
VCNL36828P BASIC CHARACTERISTICS PARAMETER TEST CONDITION SYMBOL MIN TYP MAX UNIT ASIC VCSEL PHOTODIODE Notes
12 предложений от 3 поставщиков
Зенер
Россия и страны ТС
VCNL36828P
от 71 ₽
Элитан
VCNL36828P
168 ₽
VCNL36828P
от 205 ₽
VCNL36828P
www.vishay.com Vishay Semiconductors
(Tamb = 25 °C, unless otherwise specified)
PARAMETER TEST CONDITION SYMBOL MIN. TYP. MAX. UNIT ASIC
Supply voltage VDD 1.65 1.80 2.00 V Shutdown state; light condition = dark; - 1 - VDD = 1.8 V Supply current (1) IDD μA Idle state (2); VDD = 1.8 V - 5 - Active state (2); VDD = 1.8 V - 330 - I2C supply voltage VPULL UP 1.2 1.8 3.6 V I2C signal input, logic high VDD = 1.8 V VIH 1 - - V I2C signal input, logic low VDD = 1.8 V VIL - - 0.5 V
VCSEL
Supply voltage of the VCSEL (3) VVCSEL 2.62 - 3.60 V Forward voltage IF = 9 mA VF - 1.92 - V Forward current IF 7 - 20 mA Angle of half intensity ϕ - ± 4.5 - ° Peak wavelength IF = 9 mA λp - 940 - nm Spectral bandwidth IF = 9 mA Δλ - 3 - nm
PHOTODIODE
X-axis (4) - ± 60 - Angle of half sensitivity ϕ ° Y-axis (4) - ± 45 - Peak sensitivity wavelength λp - 850 - nm
Notes
(1) Actual current consumption depends on the register settings. Please refer to the application note on the current consumption (2) Excluding VCSEL driving current (3) VVCSEL should at least match the minimum required supply voltage for the VCSEL VVCSEL, min. Please refer to the VVCSEL, min table (4) Cross section of the package INT 1 6 SDA ASIC PD V 2 5 SCL DD X-axis VCSEL GND 3 4 VCSELA Y-axis
VVCSEL, MIN. PS_CURRENT (I
F
7 mA 9 mA 11 mA 12 mA 15 mA 17 mA 19 mA 20 mA
VVCSEL, min.
2.62 V 2.74 V 2.86 V 2.91 V 3.08 V 3.19 V 3.3 V 3.36 V
VVCSEL, max.
3.6 V Rev. 1.2, 16-Nov-2023
3
Document Number: 80306 For technical questions, contact: sensorstechsupport@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
