Datasheet TSB711, TSB711A TSB712, TSB712A (STMicroelectronics) - 2
ПроизводительSTMicroelectronics
ОписаниеPrecision Rail-To-Rail Input/Output 36 V, 6 MHz Op Amps
Страниц / Страница32 / 2 — TSB711, TSB711A, TSB712, TSB712A. Pin description. Figure 1. TSB711 pin …
Формат / Размер файлаPDF / 4.3 Мб
TSB711, TSB711A, TSB712, TSB712A. Pin description. Figure 1. TSB711 pin connections (top view)
TSB711, TSB711A, TSB712, TSB712A Pin description Figure 1 TSB711 pin connections (top view)
40 предложений от 11 поставщиков
Операционный усилитель, RRIO, 2 Усилителя, 6 МГц, 3 В/мкс, 2.7В до 36В, ± 1.35В до ± 18В, SOIC
Эиком
TSB712IYDT
от 199 ₽
TSB712IYDT
286 ₽
TSB712IYDT
от 309 ₽
TSB712IYDT
TSB711, TSB711A, TSB712, TSB712A Pin description 1 Pin description Figure 1. TSB711 pin connections (top view)
OUT VCC+ VCC- IN+ IN- SOT23-5
Table 1. TSB711 pin description (SOT23-5) Pin n° Pin name Description
1 OUT Output channel 2 VCC- Negative supply voltage 3 IN1+ Non-inverting input channel 4 IN- Inverting input channel 5 VCC+ Positive supply voltage
Figure 2. TSB712 pin connections (top view)
OUT1 VCC+ IN1- OUT2 IN1+ IN2- VCC- IN2+ MiniSO8/SO8
Table 2. TSB712 pin description (miniSO8/SO8) Pin n° Pin name Description
1 OUT1 Output channel 1 2 IN1- Inverting input channel 1 3 IN1+ Non-inverting input channel 1 4 VCC- Negative supply voltage 5 IN2+ Non-inverting input channel 2 6 IN2- Inverting input channel 2 7 OUT2 Output channel 2 8 VCC+ Positive supply voltage
DS12487
Rev 7 page 2/32
Document Outline TSB711, TSB711A, TSB712, TSB712A 1 Pin description 2 Absolute maximum ratings and operating conditions 3 Electrical characteristics 4 Typical performance characteristics 5 Application information 5.1 Operating voltages 5.2 Input pin voltage range 5.3 Rail-to-rail input stage 5.4 Input offset voltage drift over the temperature 5.5 Long term input offset voltage drift 5.6 EMI rejection 5.7 Maximum power dissipation 5.8 Capacitive load and stability 5.9 PCB layout recommendations 5.10 Decoupling capacitor 6 Typical applications 6.1 Low-side current sensing 7 Package information 7.1 SOT23-5 package information 7.2 MiniSO8 package information 7.3 SO8 package information 8 Ordering information Revision history
