Оптопары и оптореле Megawin
Datasheet TSB711, TSB711A TSB712, TSB712A (STMicroelectronics) - 3
ПроизводительSTMicroelectronics
ОписаниеPrecision Rail-To-Rail Input/Output 36 V, 6 MHz Op Amps
Страниц / Страница32 / 3 — TSB711, TSB711A, TSB712, TSB712A. Absolute maximum ratings and operating …
Формат / Размер файлаPDF / 4.3 Мб
TSB711, TSB711A, TSB712, TSB712A. Absolute maximum ratings and operating conditions. Table 3. Absolute maximum ratings
TSB711, TSB711A, TSB712, TSB712A Absolute maximum ratings and operating conditions Table 3 Absolute maximum ratings
40 предложений от 12 поставщиков
Операционный усилитель, RRIO, 2 Усилителя, 6 МГц, 3 В/мкс, 2.7В до 36В, ± 1.35В до ± 18В, Mini SOIC
TSB712IYST
54 ₽
Зенер
Россия и страны ТС
TSB712IYST
от 70 ₽
TSB712IYST
127 ₽
TSB712IYST
203 ₽
link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 3 link to page 15 link to page 15 link to page 15
TSB711, TSB711A, TSB712, TSB712A Absolute maximum ratings and operating conditions 2 Absolute maximum ratings and operating conditions Table 3. Absolute maximum ratings Symbol Parameter Value Unit
VCC Supply voltage (1) +40 or ±20 V Vid Input voltage differential (2) ±2 V Vin Input voltage (VCC-) - 0.2 to (VCC+) + 0.2 V Iin Input current (3) ±10 mA Storage temperature -65 to +150 °C Thermal resistance junction-to-ambient (4) (5) MiniSO-8 190 Rth-ja °C / W SO8 125 SOT23-5 250 Tj Maximum junction temperature 150 °C HBM: human body model (6) 2 kV ESD CDM: charged device model (7) 1 kV Latch-up immunity 100 mA 1. All voltage values, except the differential voltage are with respect to the network ground terminal. 2. Differential voltages are the non-inverting input terminal with respect to the inverting input terminal. The maximum input voltage differential value may be extended to the condition that the input current is limited to ±10 mA. See Section 5.2 Input pin voltage range. 3. Input current must be limited by a resistor in series with the inputs when the input voltage is beyond the rails (see Section 5.2 Input pin voltage range). 4. Short-circuits can cause excessive heating and destructive dissipation. 5. Rth are typical values. 6. Human body according to JEDEC standard JESD22-A114F. 7. According to ANSI/ESD STM5.3.1.
Table 4. Operating conditions Symbol Parameter Value
VCC Supply voltage 2.7 V to 36 V Vicm Common mode input voltage range (VCC-) to (VCC+) + 0.1 V Toper Operating free air temperature range -40 °C to +125 °C
DS12487
Rev 7 page 3/32
Document Outline TSB711, TSB711A, TSB712, TSB712A 1 Pin description 2 Absolute maximum ratings and operating conditions 3 Electrical characteristics 4 Typical performance characteristics 5 Application information 5.1 Operating voltages 5.2 Input pin voltage range 5.3 Rail-to-rail input stage 5.4 Input offset voltage drift over the temperature 5.5 Long term input offset voltage drift 5.6 EMI rejection 5.7 Maximum power dissipation 5.8 Capacitive load and stability 5.9 PCB layout recommendations 5.10 Decoupling capacitor 6 Typical applications 6.1 Low-side current sensing 7 Package information 7.1 SOT23-5 package information 7.2 MiniSO8 package information 7.3 SO8 package information 8 Ordering information Revision history
