Datasheet CPC1004N (Littelfuse) - 2
ПроизводительLittelfuse
Описание100V, 300mA Single-Pole Normally Open Relay
Страниц / Страница6 / 2 — CPC1004N. Absolute Maximum Ratings @ 25ºC. Parameter. Ratings. Units
Формат / Размер файлаPDF / 195 Кб
CPC1004N Absolute Maximum Ratings @ 25ºC Parameter Ratings Units
32 предложений от 15 поставщиков
Твердотельные реле - Печатного монтажа SS Relay SP, NO 4-PIN SOP OptoMOS
ЧипСити
CPC1004N
Littelfuse
111 ₽
CPC1004N
126 ₽
CPC1004N микросхема
CPC1004N
IXYS
INTEGRATED CIRCUITS DIVISION
Absolute Maximum Ratings are stress ratings. Stresses in Blocking Voltage 100 V excess of these ratings can cause permanent damage to the P Reverse Input Voltage 5 V device. Functional operation of the device at conditions beyond those indicated in the operational sections of this data sheet is Input Control Current 50 mA not implied. Peak (10ms) 1 A Input Power Dissipation 1 70 mW Typical values are characteristic of the device at +25°C, and Total Power Dissipation 2 400 mW are the result of engineering evaluations. They are provided for Capacitance Input to Output 1 pF information purposes only, and are not part of the manufacturing Isolation Voltage, Input to Output 1500 V testing requirements. rms Operational Temperature, Ambient -40 to +110 °C Storage Temperature -40 to +125 °C 1 Derate linearly 1.33 mW / ºC 2 Derate output power linearly 3.33 mW / ºC
Electrical Characteristics @ 25°C (Unless Otherwise Specifi ed) Parameter Conditions Symbol Min Typ Max Units Output Characteristics
Blocking Voltage I =1A V 100 - - V L DRM Load Current Continuous 1 - - - 300 IL Continuous T=110°C, I =10mA - - 100 mA F DC Peak t=10ms I - - 500 LPK On-Resistance 2 I =300mA R - - 4 L ON Off-State Leakage Current V =100V I - - 1 µA L P LEAK Switching Speeds Turn-On t - - 3 I =5mA, V =10V on ms F L Turn-Off t - - 1 off Output Capacitance I =0mA, V =50V, f=1MHz C - 25 - pF F L OUT
Input Characteristics
Input Control Current to Activate I =300mA I - 0.9 2 mA L F Input Control Current to Deactivate - I 0.3 0.8 - mA F Input Voltage Drop I =5mA V 0.9 1.36 1.5 V F F Reverse Input Current V =5V I - - 10 µA R R 1 Load current derates linearly from 300mA @ 25oC to 100mA @ 110oC. 2 Measurement taken within 1 second of on-time.
2 www.ixysic.com
R10
