Datasheet PA05 (Apex) - 6
ПроизводительApex
ОписаниеPower Operational Amplifier
Страниц / Страница15 / 6 — PA05. OUTPUT. PA05A. Parameter. Test. Conditions. Units. Min. Typ. Max. …
Формат / Размер файлаPDF / 829 Кб
PA05. OUTPUT. PA05A. Parameter. Test. Conditions. Units. Min. Typ. Max. POWER SUPPLY
PA05 OUTPUT PA05A Parameter Test Conditions Units Min Typ Max POWER SUPPLY
PA05 OUTPUT PA05 PA05A Parameter Test Conditions Units Min Typ Max Min Typ Max
Voltage Swing IOUT = 20A ±VS–9.5 ±VS–8.7 * * V V Voltage Swing B =Vs + 5V, ±V I S–5.8 ±VS–5.0 * * V OUT = 30A Current, peak 30 * A A Settling Time to 0.1% V = +1, 10V step, RL = 4 Ω 2.5 * µs A Slew Rate V = –10, CC = 82pF, RC = 120 Ω 80 100 * * V/µs Ful temp range, Capacitive Load AV = +1 2.2 * nF IOUT = 0, No load, 5 * Ω Resistance 2 MHz IOUT = 1A, 2 MHz 2 * Ω
POWER SUPPLY PA05 PA05A Parameter Test Conditions Units Min Typ Max Min Typ Max
Voltage Ful temp range ±15 ±45 ±50 * * * V Current, quiescent, boost supply 46 56 * * mA Current, quiescent, total 90 120 * * mA Current, quiescent, total, shut- down 46 56 * * mA 6 PA05U Rev O Document Outline PA05 Features Applications Description Figure 1: Equivalent Schematic Typical Connection Figure 2: Typical Connections Pinout and Description Table Figure 3: External Connections Specifications Absolute Maximum Ratings Input Gain Output Power Supply Thermal Typical Performance Graphs SAFE OPERATING AREA (SOA) 1. The current handling capability of the MOSFET geometry and the wire bonds. 2. The junction temperature of the output MOSFETs. Figure 16: SOA General Typical Application Figure 17: Typical Application Phase Compensation Current Limit Figure 18: Current Limit Shutdown Operation Figure 19: Shutdown Operation Boost Operation Compensation Package Design Package Style CR
