Datasheet FDS6675 (Fairchild) - 3
ПроизводительFairchild
ОписаниеSingle P-Channel Logic Level PowerTrench MOSFET
Страниц / Страница9 / 3 — Electrical Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. …
Формат / Размер файлаPDF / 356 Кб
Electrical Characteristics. Symbol. Parameter. Conditions. Min. Typ. Max. Units. OFF CHARACTERISTICS. ON CHARACTERISTICS
Electrical Characteristics Symbol Parameter Conditions Min Typ Max Units OFF CHARACTERISTICS ON CHARACTERISTICS
45 предложений от 30 поставщиков
MOSFET P-CH 30V 8-SOIC. P-Channel 30V 11A (Ta) 2.5W (Ta) Surface Mount 8-SOIC. Transistors - FETs, MOSFETs - Single
Зенер
Россия и страны ТС
FDS6675BZ-G
50 ₽
Элитан
FDS6675BZ
58 ₽
Триема
FDS6675 SO8 транзистор
132 ₽
FDS6675BZ_NL
Fairchild
(T = 25 OC unless otherwise noted ) A
BV Drain-Source Breakdown Voltage V = 0 V, I = -250 µA -30 V DSS GS D ∆BV /∆T Breakdown Voltage Temp. Coefficient I = -250 µA, Referenced to 25 oC -22 mV/oC DSS J D I Zero Gate Voltage Drain Current V = -24 V, V = 0 V -1 µA DSS DS GS T = 55°C -10 µA J I Gate - Body Leakage, Forward V = 20 V, V = 0 V 100 nA GSSF GS DS I Gate - Body Leakage, Reverse V = -20 V, V = 0 V -100 nA GSSR GS DS
ON CHARACTERISTICS
(Note 2) V Gate Threshold Voltage V = V , I = -250 µA -1 -1.7 -3 V GS(th) DS GS D ∆V /∆T Gate Threshold Voltage Temp. Coefficient I = 250 µA, Referenced to 25 oC 4.3 mV/oC GS(th) J D R Static Drain-Source On-Resistance V = -10 V, I = -11 A 0.011 0.014 Ω DS(ON) GS D T =125°C 0.016 0.023 J V = -4.5 V, I = -9 A 0.015 0.02 GS D I On-State Drain Current V = -10 V, V = -5 V -50 A D(ON) GS DS g Forward Transconductance V = -10 V, I = -11 A 32 S FS DS D
DYNAMIC CHARACTERISTICS
C Input Capacitance V = -15 V, V = 0 V, 3000 pF iss DS GS f = 1.0 MHz C Output Capacitance 870 pF oss C Reverse Transfer Capacitance 360 pF rss
SWITCHING CHARACTERISTICS
(Note 2) t Turn - On Delay Time V = -15 V, I = -1 A 12 22 ns D(on) DS D t Turn - On Rise Time r V = -10 V, R = 6 Ω 16 27 ns GEN GEN t Turn - Off Delay Time 50 80 ns D(off) t Turn - Off Fall Time 100 140 ns f Q Total Gate Charge V = -15 V, I = -11 A, 30 42 nC g DS D Q Gate-Source Charge V = -5 V 9 nC gs GS Q Gate-Drain Charge 11 nC gd
DRAIN-SOURCE DIODE CHARACTERISTICS AND MAXIMUM RATINGS
I Maximum Continuous Drain-Source Diode Forward Current -2.1 A S V Drain-Source Diode Forward Voltage V = 0 V, I = -2.1 A (Note 2) -0.72 -1.2 V SD GS S Notes: 1. Rθ is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting surface of the drain pins. R is guaranteed by JA θJC design while Rθ is determined by the user's board design. CA b. 105OC/W on a 0.02 in2 a. 50OC/W on a 0.5 in2 c. 125OC/W on a 0.003 in2 pad pad of 2oz copper. pad of 2oz copper. of 2oz copper. Scale 1 : 1 on letter size paper 2. Pulse Test: Pulse Width < 300µs, Duty Cycle < 2.0%. www.onsemi.com 2
