Datasheet MOC3031M, MOC3032M, MOC3033M, MOC3041M, MOC3042M, MOC3043M (ON Semiconductor) - 6
ПроизводительON Semiconductor
Описание6-Pin DIP Zero-Cross Triac Driver Output Optocoupler (250/400 Volt Peak)
Страниц / Страница12 / 6 — MOC3031M, MOC3032M, MOC3033M, MOC3041M, MOC3042M, MOC3043M. APPLICATION …
Формат / Размер файлаPDF / 329 Кб
MOC3031M, MOC3032M, MOC3033M, MOC3041M, MOC3042M, MOC3043M. APPLICATION INFORMATION
MOC3031M, MOC3032M, MOC3033M, MOC3041M, MOC3042M, MOC3043M APPLICATION INFORMATION
26 предложений от 14 поставщиков
Оптотиристор; 4,17кВ; с системой переключения в нуле; DIP6; Ch: 1
MOC3041TVM
38 ₽
MOC3041TVM
от 113 ₽
Hi-Tech Circuit Group
MOC3041TVM
Fairchild
MOC3041TVM
Fairchild
link to page 6 link to page 6
Typical circuit (Figure 9, 10) for use when hot line the MOC3032M and MOC3042M, or 15 mA for the switching is required. In this circuit the “hot” side of the line MOC3031M and MOC3041M. The 39 ohm resistor and is switched and the load connected to the cold or neutral side. 0.01 mF capacitor are for snubbing of the triac and may or The load may be connected to either the neutral or hot line. may not be necessary depending upon the particular triac Rin is calculated so that IF is equal to the rated IFT of the and load used. part, 5 mA for the MOC3033M and MOC3043M, 10 mA for Rin 1 6 180 W Rin 1 6 360 W VCC HOT VCC HOT 2 MOC3031M 5 2 MOC3041M 5 MOC3032M MOC3042M 39 39 MOC3033M W* MOC3043M W* 3 4 115 VAC 3 4 240 VAC 0.01 0.01 1 kW 330 W LOAD NEUTRAL LOAD NEUTRAL *For highly inductive loads (power factor < 0.5), change this value to 360 ohms. *For highly inductive loads (power factor < 0.5), change this value to 360 ohms.
Figure 9. Hot−Line Switching Application Circuit Figure 10. Hot−Line Switching Application Circuit (MOC3031M, MOC3032M, MOC3033M) (MOC3041M, MOC3042M, MOC3043M)
115 VAC R1 D1 1 6 VCC R MOC3031M in 2 5 SCR MOC3032M SCR MOC3033M 180 W 3 4 R2 D2 LOAD
Figure 11. Inverse−Parallel SCR Driver Circuit (MOC3031M, MOC3032M, MOC3033M)
Suggested method of firing two, back−to−back SCR’s with a
onsemi
triac driver. Diodes can be 1N4001; resistors, R1 and R2, are optional 1 kW.
www.onsemi.com 6
