Datasheet NCP1729 (ON Semiconductor) - 9
ПроизводительON Semiconductor
ОписаниеSwitched Capacitor Voltage Inverter
Страниц / Страница22 / 9 — NCP1729. Figure 22. Negative Output Voltage Doubler. Curve. in (V). All …
Формат / Размер файлаPDF / 181 Кб
NCP1729. Figure 22. Negative Output Voltage Doubler. Curve. in (V). All Diodes. out (. Figure 23. Doubler Load Regulation,
NCP1729 Figure 22 Negative Output Voltage Doubler Curve in (V) All Diodes out ( Figure 23 Doubler Load Regulation,
18 предложений от 17 поставщиков
Charge Pump Switching Regulator IC Positive or Negative Fixed -Vin, nVin 1 Output 50mA SOT-23-6 Thin, TSOT-23-6
NCP1729SN35T1
147 ₽
NCP1729SN35T1G
ТаймЧипс
NCP1729SN35T1/ADE8
NCP1729SN35T1
NCP1729
1 6 OSC −Vout Vin 2 5 + + + + + 3 4 Capacitors = 3.3 F
A single device can be used to construct a negative voltage doubler. The output voltage is approximately equal to −2.0 Vin minus the forward voltage drop of each external diode. The performance characteristics for the above converter are shown below. Note that curves A and C show the circuit performance with economical 1N4148 diodes, while curves B and D are with lower loss MBRA120E Schottky diodes. 0 TA = 25°C −2.0 A AGE (V) T
Curve V R
−4.0
in (V) All Diodes out ( )
B A 3.0 1N4148 118 −6.0 C B 3.0 MBRA120E 107 , OUTPUT VOL out −8.0 C 5.0 1N4148 91 V D D 5.0 MBRA120E 85 −10.0 0 10 20 30 40 Iout, OUTPUT CURRENT (mA)
Figure 23. Doubler Load Regulation, Output Voltage vs. Output Current http://onsemi.com 9
