Линейка продуктов KEEN SIDE
Datasheet NCP1729 (ON Semiconductor) - 10
ПроизводительON Semiconductor
ОписаниеSwitched Capacitor Voltage Inverter
Страниц / Страница22 / 10 — NCP1729. Figure 24. Negative Output Voltage Tripler. Curve. Vin (V). All …
Формат / Размер файлаPDF / 181 Кб
NCP1729. Figure 24. Negative Output Voltage Tripler. Curve. Vin (V). All Diodes. Rout (. Figure 25. Tripler Load Regulation, Output
NCP1729 Figure 24 Negative Output Voltage Tripler Curve Vin (V) All Diodes Rout ( Figure 25 Tripler Load Regulation, Output
Charge Pump Switching Regulator IC Positive or Negative Fixed -Vin, nVin 1 Output 50mA SOT-23-6 Thin, TSOT-23-6
727GS
NCP1729SN35T1G
от 46 ₽
NCP1729SN35T1G
153 ₽
SUV System
NCP1729SN35T1G
NCP1729SN35T1G
NCP1729
1 6 OSC −Vout Vin 2 5 + + + + + + + 3 4 Capacitors = 3.3 F
A single device can be used to construct a negative voltage tripler. The output voltage is approximately equal to −3.0 Vin minus the forward voltage drop of each external diode. The performance characteristics for the above converter are shown below. Note that curves A and C show the circuit performance with economical 1N4148 diodes, while curves B and D are with lower loss MBRA120E Schottky diodes. 0 −2.0 A −4.0 AGE T C B −6.0
Curve Vin (V) All Diodes Rout ( )
−8.0 A 3.0 1N4148 247 −10.0 D B 3.0 MBRA120E 228 , OUTPUT VOL out −12.0 V C 5.0 1N4148 198 −14.0 TA = 25°C D 5.0 MBRA120E 188 −16.0 0 10 20 30 40 50 Iout, OUTPUT CURRENT
Figure 25. Tripler Load Regulation, Output Voltage vs. Output Current http://onsemi.com 10
