Datasheet MAX4754, MAX4754A, MAX4755, MAX4756, MAX4756A (Maxim) - 6
| Производитель | Maxim |
| Описание | 0.5Ω, Quad SPDT Switches in UCSP/QFN |
| Страниц / Страница | 15 / 6 — 0.5. , Quad SPDT Switches in UCSP/QFN. Typical Operating Characteristics … |
| Формат / Размер файла | PDF / 325 Кб |
0.5. , Quad SPDT Switches in UCSP/QFN. Typical Operating Characteristics (continued). SUPPLY CURRENT
0.5
Ω
, Quad SPDT Switches in UCSP/QFN Typical Operating Characteristics (continued)
(V+ = 3V, TA = +25°C, unless otherwise noted.)
SUPPLY CURRENT SUPPLY CURRENT vs. TEMPERATURE CHARGE INJECTION vs. VCOM vs. SUPPLY VOLTAGE (MAX4754/MAX4755/MAX4756)
250 2.0 100 CI = 1nF 1.8 200 1.6 10 V+ = 5V MAX4754-56 toc12 MAX4754A-56A toc10 MAX4754A-56A toc11 1.4 150 1.2 1 V+ = 5V 1.0 100 0.8 0.1 V+ = 3.0V CHARGE INJECTION (pC) SUPPLY CURRENT (nA) 0.6 SUPPLY CURRENT (nA) 50 0.4 0.01 0.2 V+ = 3V 0 0 0.001 0 1 2 3 4 5 1 2 3 4 5 6 -40 -15 10 35 60 85 VCOM (V) SUPPLY VOLTAGE (V) TEMPERATURE (°C)
SUPPLY CURRENT vs. TEMPERATURE LOGIC THRESHOLD vs. SUPPLY VOLTAGE LOGIC THRESHOLD vs. SUPPLY VOLTAGE (MAX4754A/MAX4756A) (MAX4754/MAX4755/MAX4756) (MAX4754A/MAX4756A)
100 2.4 1.4 VIH 2.0 1.2 10 V+ = 5.0V MAX4754A-56A toc13 MAX4754A-56A toc14 MAX4754A-56A toc15 1.0 VIH 1.6 VIL 1 0.8 VII 1.2 0.6 0.1 V+ = 3.0V 0.8 SUPPLY CURRENT (nA) LOGIC THRESHOLD (V) LOGIC THRESHOLD (V) 0.4 0.01 0.4 0.2 0.001 0 0.0 -40 -15 -10 35 60 85 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.5 2.5 3.5 4.5 5.5 TEMPERATURE (°C) SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V)
TURN-ON/OFF TIMES vs. SUPPLY VOLTAGE TURN-ON/OFF TIMES vs. SUPPLY VOLTAGE TURN-ON/OFF TIMES vs. TEMPERATURE (MAX4754/MAX4755/MAX4756) (MAX4754A) (MAX4754/MAX4755/MAX4756)
70 800 50 60 700 40 MAx4754A-56A toc16 600 50 MAX4754A-56A toc17 MAX4754A-56A toc18 tON, V+ = 3V tON, V+ = 5V 500 (ns) 40 30 (ns) t t OFF, NO ON, NC (ns) tON /t OFF 400 /t OFF /t OFF t ON 30 t ON t ON 20 t 300 OFF 20 200 tON, NO tOFF, NC 10 t t OFF, V+ = 3V OFF, V+ = 5V
MAX4754/MAX4754A/MAX4755/MAX4756/MAX4756A
10 100 0 0 0 1.5 2.0 2.5 3.0 3.5 4.0 4.5 5.0 5.5 1.5 2.5 3.5 4.5 5.5 -40 -15 10 35 60 85 SUPPLY VOLTAGE (V) SUPPLY VOLTAGE (V) TEMPERATURE (°C)
6 _______________________________________________________________________________________
