Datasheet MAX3280E, MAX3281E, MAX3283E, MAX3284E (Analog Devices) - 3
Описание±15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers
Страниц / Страница11 / 3 — Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. …
Electrical Characteristics. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. RECEIVER. ESD PROTECTION
Electrical Characteristics PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS RECEIVER ESD PROTECTION
39 предложений от 17 поставщиков
Чип интерфейса, RS-422/RS-485Interface IC 15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers
MAX3284EAUT+T
Maxim
от 24 ₽
MAX3284EAUT+T
Maxim
42 ₽
MAX3284EAUT+T
Maxim
от 344 ₽
Hi-Tech Circuit Group
MAX3284EAUT-T
MAX3280E/MAX3281E/ ±15kV ESD-Protected 52Mbps, 3V to 5.5V, MAX3283E/MAX3284E SOT23 RS-485/RS-422 True Fail-Safe Receivers
(VCC = 3V to 5.5V, VL = VCC, TA = TMIN to TMAX, unless otherwise noted. Typical values are at VCC = 5V and TA = +25°C.) (Notes 2, 3)
Supply Voltage VCC 3.0 5.5 V Supply Current ICC No load 9 15 mA VL Input Range VL MAX3284E 1.65 VCC V VL Supply Current IL No load (MAX3284E) 10 µA
RECEIVER
VIN = +12V 250 Input Current (A and B) IA, B VCC = VGND or 5.5V µA VIN = -7V -200 Receiver Differential Threshold V Voltage TH -7V ≤ VCM ≤ +12V (Note 4) -200 -125 -50 mV Receiver Input Hysteresis ∆VTH VA + VB = 0V 25 mV Receiver Enable Input Low VENIL MAX3281E, MAX3283E only 0.4 V Receiver Enable Input High VENIH MAX3281E, MAX3283E only 2 V Receiver Enable Input Leakage ILEAK MAX3281E, MAX3283E only ±10 µA MAX3280E/MAX3281E/MAX3283E, V I CC - 0.4 OH = -4mA, RO high Receiver Output High Voltage VOH V MAX3284E, IOH = -1mA, 1.65V ≤ VL ≤ VCC, V RO high L - 0.4 MAX3280E/MAX3281E/MAX3283E, 0.4 IOL = 4mA, RO low Receiver Output Low Voltage VOL V MAX3284E, IOL = 1mA, 1.65V ≤ VL ≤ VCC, 0.4 RO low Three-State Output Current at I Receiver OZR 0 ≤ VO ≤ VCC, RO = high impedance ±5 µA Receiver Input Resistance RIN -7V ≤ VCM ≤ +12V (Note 5) 48 kW Receiver Output Short-Circuit I Current OSR 0 ≤ VRO ≤ VCC ±130 mA
ESD PROTECTION
Human Body Model ±15 ESD Protection (A, B) IEC1000-4-2 (Air-Gap Discharge) ±12 kV IEC1000-4-2 (Contact Discharge) ±6 www.maximintegrated.com Maxim Integrated │ 3
