Datasheet MAX3280E, MAX3281E, MAX3283E, MAX3284E (Analog Devices) - 5
Описание±15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers
Страниц / Страница11 / 5 — Typical Operating Characteristics (continued). RECEIVER OUTPUT LOW …
Typical Operating Characteristics (continued). RECEIVER OUTPUT LOW VOLTAGE. RECEIVER PROPAGATION DELAY (tPLH)
Typical Operating Characteristics (continued) RECEIVER OUTPUT LOW VOLTAGE RECEIVER PROPAGATION DELAY (tPLH)
39 предложений от 17 поставщиков
Чип интерфейса, RS-422/RS-485Interface IC 15kV ESD-Protected 52Mbps, 3V to 5.5V, SOT23 RS-485/RS-422 True Fail-Safe Receivers
MAX3284EAUT-T
Maxim
43 ₽
ЧипСити
MAX3284EAUT+T
Maxim
87 ₽
MAX3284EAUT+T
Контест
MAX3284EAUT+T
MAX3280E/MAX3281E/ ±15kV ESD-Protected 52Mbps, 3V to 5.5V, MAX3283E/MAX3284E SOT23 RS-485/RS-422 True Fail-Safe Receivers
(VCC = 3.3V, TA = +25°C, unless otherwise noted.)
RECEIVER OUTPUT LOW VOLTAGE RECEIVER PROPAGATION DELAY (tPLH) RECEIVER PROPAGATION DELAY (tPHL) vs. TEMPERATURE vs. TEMPERATURE vs. TEMPERATURE
200 9 10 8 150 9 MAX3280/1/3/4E toc04 MAX3280/1/3/4E toc05 MAX3280/1/3/4E toc06 VCC = 3.3V VCC = 5V 7 VCC = 5V (ns) (ns) 100 VCC = 5V V 8 t PLH CC = 3.3V t PHL VCC = 3.3V 6 50 7 5 RECEIVER OUTPUT LOW VOLTAGE (mV) A = GND, VB = 1V, IOL = 4mA 0 4 6 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 -50 -25 0 25 50 75 100 125 TEMPERATURE (°C) TEMPERATURE (°C) TEMPERATURE (°C)
MAX3284E MAXIMUM DATA RATE SUPPLY CURRENT vs. TEMPERATURE vs. VOLTAGE LOGIC LEVEL
9 60 VCC = 5V 8 50 MAX3280/1/3/4E toc07 MAX3280/1/3/4E toc08 7 40 DATA RATE (Mbps) SUPPLY CURRENT (mA) 6 30 VCC = 3.3V 5 20 -50 -25 0 25 50 75 100 125 1.5 2.5 3.5 4.5 5.5 TEMPERATURE (°C) VOLTAGE LOGIC LEVEL (V)
VL SUPPLY CURRENT SUPPLY CURRENT vs. DATA RATE vs. TEMPERATURE
10 10 ICC, VCC = VL = 5V 8 1 VCC = VL = 5V MAX3280/1/3/4 toc10 MAX3280/1/3/4E toc09 DATA RATE = 52Mbps VCC = VL = 3.3V ICC, VCC = VL = 3.3V DATA RATE = 52Mbps 6 0.1 IL, VCC = VL = 5V 4 VCC = VL = 5V SUPPLY CURRENT (mA) DATA RATE = 100kbps SUPPLY CURRENT (mA) V L 0.01 2 VCC = VL = 3.3V IL, VCC = VL = 3.3V DATA RATE = 100kbps 0.001 0 -50 -25 0 25 50 75 100 125 10 100 1000 10,000 100,000 TEMPERATURE (°C) DATA RATE (kbps) www.maximintegrated.com Maxim Integrated │ 5
