Datasheet ADR1001 (Analog Devices) - 10
ОписаниеOven-Controlled, Buried Zener, Precision Voltage Reference
Страниц / Страница21 / 10 — ADR1001. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 9. Reference Voltage …
Формат / Размер файлаPDF / 2.6 Мб
ADR1001. TYPICAL PERFORMANCE CHARACTERISTICS. Figure 9. Reference Voltage Error vs. Temperature, 6.6 V Output, Referred to
ADR1001 TYPICAL PERFORMANCE CHARACTERISTICS Figure 9 Reference Voltage Error vs Temperature, 6.6 V Output, Referred to
ADR1001AEZ
от 14 454 ₽
Элитан
ADR1001AEZ
19 254 ₽
Data Sheet
ADR1001 TYPICAL PERFORMANCE CHARACTERISTICS Figure 9. Reference Voltage Error vs. Temperature, 6.6 V Output, Referred to Figure 12. Long-Term Drift, 5 V Output, Mean and Sigmas +20°C Figure 13. Long-Term Drift, 6.6 V Output Figure 10. Reference Voltage vs. Temperature, 6.6 V Output Figure 14. Long-Term Drift, 6.6 V Output, Mean and Sigmas Figure 11. Long-Term Drift, 5 V Output analog.com Rev. 0 | 10 of 21
Document Outline Features Applications General Description Functional Block Diagram Specifications 6.6 V Reference Characteristics Heater Amplifier Electrical Characteristics 5 V Output and Buffer Electrical Characteristics Voltage Divider Characteristics Absolute Maximum Ratings Thermal Resistance Electrostatic Discharge (ESD) Ratings ESD Ratings for the ADR1001 ESD Caution Pin Configuration and Function Descriptions Typical Performance Characteristics Theory of Operation Buried Zener Reference Loop Thermal Regulator Heater Current Limiting Setting the ADR1001 Operating Temperature Precision Voltage Divider and Output Buffer Power Good External Resistor Sensitivity Capacitors Noise Performance Electromechanical Stability Solder Heat Resistance (SHR) Shift Applications Information Basic Connections Outline Dimensions Ordering Guide Evaluation Boards
