Datasheet MAX4165, MAX4166, MAX4167, MAX4168, MAX4169 (Analog Devices) - 8
ОписаниеHigh-Output-Drive, Precision, Low-Power, Single-Supply, Rail-to-Rail I/O Op Amps with Shutdown
Страниц / Страница17 / 8 — High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O …
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown. Pin Description. PIN
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown Pin Description PIN
IC OPAMP GP 4 CIRCUIT 14SOIC. General Purpose Amplifier 4 Circuit Rail-to-Rail 14-SOIC. Linear - Amplifiers - Instrumentation, OP Amps, Buffer...
Рутоника
MAX4169ESD+T
Maxim
186 ₽
MAX4169ESD
Maxim
от 915 ₽
727GS
MAX4169ESD
Maxim
SUV System
MAX4169ESD
High-Output-Drive, Precision, Low-Power, Single- Supply, Rail-to-Rail I/O Op Amps with Shutdown Pin Description PIN MAX4166 MAX4168 NAME FUNCTION MAX4165 DIP/SO MAX4167 MAX4169 DIP/SO (MAX (MAX (DFN
1 6 4 — — — — OUT Output 5, 7, 8, — 1, 5 2, 6 — — — N.C. No Connection. Not internal y connected. 10 — — — 1, 7 1, 13 1, 9 1, 7 OUT1, OUT2 Outputs for Amplifiers 1 and 2 Negative Supply. Ground for single- 2 4 3 4 4 4 11 VEE supply operation. 3 3 1 — — — — IN+ Noninverting Input — — — 2, 6 2, 12 2, 8 2, 6 IN1-, IN2- Inverting Inputs for Amplifiers 1 and 2 4 2 7 — — — — IN- Inverting Input
MAX4165-MAX4169
— — — 3, 5 3, 11 3, 7 3, 5 IN1+, IN2+ Noninverting Inputs for Amplifiers 1 and 2 5 7 5 8 14 10 4 VCC Positive Supply Active-Low Shutdown Inputs for SHDN1, Amplifiers 1 and 2. Drive low for — — — — 6, 9 5, 6 — SHDN2 shutdown mode. Drive high or connect to VCC for normal operation. Active-Low Shutdown Input. Drive low for — 8 8 — — — — SHDN shutdown mode. Drive high or connect to VCC for normal operation. — — — — — — 8, 14 OUT3, OUT4 Outputs for Amplifiers 3 and 4 — — — — — — 9, 13 IN3-, IN4- Inverting Inputs for Amplifiers 3 and 4 — — — — — — 10, 12 IN3+, IN4+ Noninverting Inputs for Amplifiers 3 and 4
8 _______________________________________________________________________________________
