Datasheet TDA7850 (STMicroelectronics) - 9
ПроизводительSTMicroelectronics
Описание4 x 50 W MOSFET Quad Bridge Power Amplifier
Страниц / Страница18 / 9 — TDA7850. Electrical specifications. Table 4. Electrical characteristics …
Формат / Размер файлаPDF / 405 Кб
TDA7850. Electrical specifications. Table 4. Electrical characteristics (continued). Symbol. Parameter. Test condition. Min. Typ. Max. Unit
TDA7850 Electrical specifications Table 4 Electrical characteristics (continued) Symbol Parameter Test condition Min Typ Max Unit
32 предложений от 14 поставщиков
Микросхема Усилитель звуковой частоты, Audio Amp Speaker 4CH Stereo 85W Class-AB 25Pin(25+Tab) FLEXIWATT Tube
TDA7850H
1 101 ₽
TDA7850H
от 1 899 ₽
TDA7850H
2 670 ₽
TDA7850H
TDA7850 Electrical specifications Table 4. Electrical characteristics (continued)
(Refer to the test and application diagram, VS = 14.4 V; RL = 4 ; Rg = 600 ; f = 1 kHz; Tamb = 25 °C; unless otherwise specified).
Symbol Parameter Test condition Min. Typ. Max. Unit
(Amp: Mute) Att  80 dB; P 6.5 7 V Oref = 4 W AM in VS automute threshold V (Amp: Play) Att < 0.1 dB; PO = 0. 5W 7.5 8 VMUTE = 1.5 V 7 12 18 A I (Sourced Current) pin23 Muting pin current VMUTE = 3.5 V -5 18 A
HSD section
Vdropout Dropout voltage IO = 0.35 A; VS = 9 to 16 V 0.25 0.6 V Iprot Current limits 400 800 mA
Offset detector (Pin 25)
VM_ON Mute voltage for DC offset 8 V V detection enabled ST-BY = 5 V VM_OFF 6 V VOFF Detected differential output offset VST-BY = 5 V; Vmute = 8 V ±2 ±3 ±4 V Pin 25 voltage for detection = V V ST-BY = 5 V; Vmute = 8 V 25_T 0 1.5 V TRUE VOFF > ±4 V Pin 25 Voltage for detection = V V ST-BY = 5 V; Vmute = 8 V 25_F 12 V FALSE VOFF > ±2 V 1. Saturated square wave output. 9/18 Document Outline Table 1. Device summary 1 Block diagram and application circuit 1.1 Block diagram Figure 1. Block diagram 1.2 Standard test and application circuit Figure 2. Standard test and application circuit 2 Pin description Figure 3. Pin connection (top view) 3 Electrical specifications 3.1 Absolute maximum ratings Table 2. Absolute maximum ratings 3.2 Thermal data Table 3. Thermal data 3.3 Electrical characteristics Table 4. Electrical characteristics Figure 4. Components and top copper layer of the Figure 2. Figure 5. Bottom copper layer Figure 2. 3.4 Electrical characteristic curves Figure 6. Quiescent current vs. supply voltage Figure 7. Output power vs. supply voltage (RL = 4W) Figure 8. Output power vs. supply voltage (RL = 2W) Figure 9. Distortion vs. output power (RL = 4W) Figure 10. Distortion vs. output power (RL = 2W) Figure 11. Distortion vs. frequency (RL = 4W) Figure 12. Distortion vs. frequency (RL = 2W) Figure 13. Crosstalk vs. frequency Figure 14. Supply voltage rejection vs. frequency Figure 15. Output attenuation vs. supply voltage Figure 16. Power dissipation and efficiency vs. output power (RL = 4W, SINE) Figure 17. Power dissipation and efficiency vs. output power (RL = 2W, SINE) Figure 18. Power dissipation vs. output power (RL = 4W, audio program simulation) Figure 19. Power dissipation vs. output power (RL = 2W, audio program simulation) Figure 20. ITU R-ARM frequency response, weighting filter for transient pop 4 Application hints 4.1 SVR 4.2 Input stage 4.3 Standby and muting 4.4 DC offset detector 4.5 Heatsink definition 5 Package information Figure 21. Flexiwatt25 (vertical) mechanical data and package dimensions Figure 22. Flexiwatt25 (horizontal) mechanical data and package dimensions 6 Revision history Table 5. Document revision history
