Datasheet ICM7216A, ICM7216B, ICM7216D (Intersil) - 3
ПроизводительIntersil
Описание8-Digit Multi-Function Frequency Counter/Timer
Страниц / Страница17 / 3 — ICM7216A, ICM7216B, ICM7216D. Functional Block Diagram. EXT. OSC. INPUT. …
Формат / Размер файлаPDF / 196 Кб
ICM7216A, ICM7216B, ICM7216D. Functional Block Diagram. EXT. OSC. INPUT. DIGIT. DECODER. SELECT. DRIVERS. DIGIT OUTPUTS. REFERENCE. (8). OUTPUT
ICM7216A, ICM7216B, ICM7216D Functional Block Diagram EXT OSC INPUT DIGIT DECODER SELECT DRIVERS DIGIT OUTPUTS REFERENCE (8) OUTPUT
ICM7216A, ICM7216B, ICM7216D Functional Block Diagram EXT OSC INPUT 3 8 8 OSC DIGIT OSC DECODER SELECT DRIVERS INPUT DIGIT OUTPUTS OSC REFERENCE (8) OUTPUT COUNTER
103 RANGE RANGE SELECT CONTROL LOGIC LOGIC RANGE INPUT
100Hz 104 OR
106 5 STORE AND RESET RESET LOGIC INPUT CONTROL LOGIC 6 CONTROL INPUT MAIN EN
103 COUNTER DP CL OVERFLOW LOGIC EXT DP 4 4 4 4 4 4 4 4 INPUT INPUT (NOTE 2) INPUT A CONTROL DATA LATCHES AND LOGIC STORE OUTPUT MUX INPUT B (NOTE 1) DECODER SEGMENT 4 LOGIC DRIVER 7 8 SEGMENT OUTPUTS Q (8) INPUT D MEASUREMENT CONTROL CL IN PROGRESS LOGIC OUTPUT MAIN (NOTE 2) FF FUNCTION INPUT FN (NOTE 1) CONTROL LOGIC 6 HOLD INPUT
NOTES: 1. Function input and input B available on ICM7216A/B only. 2. Ext DP input and MEASUREMENT IN PROGRESS output available on ICM7216D only. 13-24
