Datasheet LMC7221 (Texas Instruments) - 6
ОписаниеTiny CMOS Comparator with Rail-To-Rail Input and Open Drain Output
Страниц / Страница24 / 6 — LMC7221. www.ti.com. Typical Performance Characteristics (continued). …
Формат / Размер файлаPDF / 924 Кб
LMC7221. www.ti.com. Typical Performance Characteristics (continued). Response Time. vs. Various Input Overdrives −tPHL. Figure 9
LMC7221 www.ti.com Typical Performance Characteristics (continued) Response Time vs Various Input Overdrives −tPHL Figure 9
47 предложений от 18 поставщиков
Компаратор миниатюрный КМОП уровень входа до напряжения питания
LMC7221BIMX/NOPB
от 15 ₽
LMC7221BIMX/NOPB
53 ₽
Элрус
LMC7221BIMX/NOPB
от 105 ₽
LMC7221BIMX/NOPB
LMC7221
SNOS748E – SEPTEMBER 1999 – REVISED MARCH 2013
www.ti.com Typical Performance Characteristics (continued) Response Time Response Time vs. vs Various Input Overdrives −tPHL Various Input Overdrives −tPHL Figure 9. Figure 10. Input Bias Current Input Bias Current vs. vs. Common Mode Voltage Common Mode Voltage Figure 11. Figure 12. Input Bias Current Input Bias Current vs. vs. Common Mode Voltage Temperature Figure 13. Figure 14.
6 Submit Documentation Feedback Copyright © 1999–2013, Texas Instruments Incorporated Product Folder Links: LMC7221 Document Outline FEATURES Applications DESCRIPTION Connection Diagram Absolute Maximum Ratings Operating Ratings 2.7V Electrical Characteristics 5.0V and 15.0V Electrical Characteristics Leakage Characteristics AC Electrical Characteristics Typical Performance Characteristics Application Information BENEFITS OF THE LMC7221 TINY COMPARATOR Size Height Simplified Board Layout Low Supply Current Wide Voltage Range Digital Outputs Representing Signal Level Open Drain Output Driving LEDs (Light Emitting Diodes) Input range to Beyond Rail to Rail Zero Crossing Detector Low Input Currents and High Input Impedance Direct Sensor Interfacing LOW VOLTAGE OPERATION OPEN DRAIN OUTPUT Output Stage OUTPUT SHORT CIRCUIT CURRENT INPUT PROTECTION LAYOUT CONSIDERATIONS PUSH-PULL OUTPUTS, DUAL VERSIONS ADDITIONAL 5-Pin SOT-23 TINY DEVICES SPICE MACROMODEL Revision History
