Datasheet AV, SMV (Pico Electronics) - 5
ПроизводительPico Electronics
ОписаниеIsolated DC-DC Converters
Страниц / Страница7 / 5 — SERIES AV/SMV - DUAL OUTPUT. Max. PICO. Full Load. Typical. Output. …
Формат / Размер файлаPDF / 309 Кб
SERIES AV/SMV - DUAL OUTPUT. Max. PICO. Full Load. Typical. Output. Surface. Input. Plug-in. Current. Power. Voltage. Mount. Part. Per O/P
SERIES AV/SMV - DUAL OUTPUT Max PICO Full Load Typical Output Surface Input Plug-in Current Power Voltage Mount Part Per O/P
PRECISION 1.25 VOLT MICROPOWER VOLTAGE REFERENCE
12AV250по запросу
SERIES AV/SMV - DUAL OUTPUT * Max ** PICO Full Load PICO Max Max Typical Output Full Load Surface Input Output Input Plug-in Current Power Full Load Voltage Output Mount Voltage Voltage Current Part Per O/P Per O/P Efficiency Ripple Voltage Price Part (V DC) (V DC) Typical Number (mA) (Watts) (%) at Tolerance Number (mA) Full Load (± %) (V p-p)
5AV100D 5SMV100D 5 ±100 6.25 0.625 78 320 0.4 3 128.59 5AV150D 5SMV150D 5 ±150 4.17 0.625 78 320 0.4 3 128.59 5AV200D 5SMV200D 5 ±200 3.13 0.625 78 320 0.4 3 150.02 5AV250D 5SMV250D 5 ±250 2.5 0.625 76 329 0.4 3 150.02 12AV100D 12SMV100D 12 ±100 6.25 0.625 80 130 0.4 3 128.59 12AV150D 12SMV150D 12 ±150 4.17 0.625 80 130 0.4 3 128.59 12AV200D 12SMV200D 12 ±200 3.13 0.625 80 130 0.4 3 150.02 12AV250D 12SMV250D 12 ±250 2.5 0.625 80 130 0.4 3 150.02 15AV100D 15SMV100D 15 ±100 6.25 0.625 81 103 0.4 3 128.59 15AV150D 15SMV150D 15 ±150 4.17 0.625 81 103 0.4 3 128.59 15AV200D 15SMV200D 15 ±200 3.13 0.625 79 106 0.4 3 150.02 15AV250D 15SMV250D 15 ±250 2.5 0.625 78 107 0.8 3 150.02 24AV100D 24SMV100D 24 ±100 6.25 0.625 80 66 0.8 3 128.59 24AV150D 24SMV150D 24 ±150 4.17 0.625 80 66 0.8 3 128.59 24AV200D 24SMV200D 24 ±200 3.13 0.625 79 66 0.8 3 150.02 24AV250D 24SMV250D 24 ±250 2.5 0.625 79 66 0.8 3 150.02 28AV100D 28SMV100D 28 ±100 6.25 0.625 79 57 0.8 3 128.59 28AV150D 28SMV150D 28 ±150 4.17 0.625 79 57 0.8 3 128.59 28AV200D 28SMV200D 28 ±200 3.13 0.625 78 58 0.8 3 150.02 28AV250D 28SMV250D 28 ±250 2.5 0.625 76 59 0.8 3 150.02 * Measured using 0.1µf, 1000 volt DC capacitor which is REQUIRED across each output and maintain at least 10% load at all times to prevent voltage surge. ** For tighter tolerances, consult factory Ordering Instructions: No minimum. Net 30 days, F.O.B. Pelham, N.Y.
Delivery: Stock to one week for sample orders AV DUAL SERIES SMV DUAL SURFACE MOUNT
