Datasheet MAX4289 (Analog Devices) - 6
Описание1.0V Micropower, SOT23, Operational Amplifier
Страниц / Страница9 / 6 — 1.0V Micropower, SOT23, Operational Amplifier. Pin Description. PIN. …
Формат / Размер файлаPDF / 287 Кб
1.0V Micropower, SOT23, Operational Amplifier. Pin Description. PIN. NAME. FUNCTION. SOT23. MAX4289. Detailed Description
1.0V Micropower, SOT23, Operational Amplifier Pin Description PIN NAME FUNCTION SOT23 MAX4289 Detailed Description
45 предложений от 16 поставщиков
Микросхема Операционный усилитель, MAXIM INTEGRATED PRODUCTS MAX4289EUT+T Operational Amplifier, 1 Amplifier, 17kHz, 0.006V/µs, 1V to 5.5V, SOT-23, 6Pins
MAX4289EUT-T
Maxim
65 ₽
MAX4289EUT+T
Maxim
135 ₽
MAX4289EUT+T
от 382 ₽
MAX4289EUT+T
Maxim
от 422 ₽
1.0V Micropower, SOT23, Operational Amplifier Pin Description PIN NAME FUNCTION SO SOT23
1, 5, 8 5 N.C. No Connection. Not internally connected. 2 4 IN- Inverting Input 3 3 IN+ Noninverting Input
MAX4289
4 2 GND Ground 6 1 OUT Amplifier Output 7 6 VCC Positive Supply. Bypass with a 0.1µF capacitor to GND.
The MAX4289 consumes ultra-low power (9µA supply current typically) and has a rail-to-rail output stage that is specifically designed for low-voltage operation. The input common-mode voltage range extends from V IN CC - 500mV/div 0.2V to ground, although full rail-to-rail input range is possible with degraded performance. The input offset voltage is typically 200µV. Low-operating supply volt- age, low supply current, and rail-to-rail outputs make this operational amplifier an excellent choice for preci- sion or general-purpose, low-voltage, battery-powered OUT V 500mV/div systems. IN = 2.0V fIN = 1kHz R
Rail-to-Rail Output Stage
L = 100kΩ The MAX4289 output stage can drive a 5kΩ load and 200µs/div still swing to within 7mV of the rails. Figure 1 shows the output voltage swing of the MAX4289 configured as a unity-gain buffer, powered from a single 2V supply volt- Figure 1. Rail-to-Rail Input/Output Voltage Range age. The output for this setup typically swings from +0.4mV to (VCC - 0.2mV) with a 100kΩ load.
SUPPLY CURRENT Applications Information vs. SUPPLY VOLTAGE
25
Power-Supply Considerations
The MAX4289 operates from a single 1.0V to 5.5V supply 20 and consumes only 9µA of supply current. A high power- µA) TA = +85°C supply rejection ratio of 75dB allows the amplifier to be powered directly off a decaying battery voltage, simplify- 15 TA = +25°C ing design and extending battery life. The MAX4289 is ideally suited for single-cell battery-powered systems. 10 T Figures 2 and 3 show the supply current and PSRR as a A = -40°C SUPPLY CURRENT ( function of supply voltage and temperature. 5 0 0 1 2 3 4 5 6 SUPPLY VOLTAGE (V) Figure 2. ICC vs. VCC Over the Temperature Range
6 _______________________________________________________________________________________
