Datasheet MAX6125, MAX6141, MAX6145, MAX6150, MAX6160 (Analog Devices) - 3
ОписаниеSOT23, Low-Cost, Low-Dropout, 3-Terminal Voltage References
Страниц / Страница12 / 3 — Electrical Characteristics—MAX6145. PARAMETER. SYMBOL. CONDITIONS. MIN. …
Electrical Characteristics—MAX6145. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX. UNITS. Electrical Characteristics—MAX6150
Electrical Characteristics—MAX6145 PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS Electrical Characteristics—MAX6150
44 предложений от 21 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
MAX6160EUS+T
Maxim
78 ₽
ЧипСити
MAX6160EUS+T
Maxim
78 ₽
MAX6160EUS-T
от 302 ₽
Hi-Tech Circuit Group
MAX6160EUS-T
MAX6125/MAX6141/ SOT23, Low-Cost, Low-Dropout, MAX6145/MAX6150/MAX6160 3-Terminal Voltage References
(VIN = 4.7V, IOUT = 0mA, TA = +25°C, unless otherwise noted.) (Note 1)
Supply Voltage VIN TA = TMIN to TMAX 4.7 12.6 V T Output Voltage V A = +25°C 4.455 4.500 4.545 OUT V TA = TMIN to TMAX 4.410 4.590 Output Voltage Temperature Coefficient TCVOUT TA = TMIN to TMAX 15 50 ppm/°C 0.1Hz to 10Hz 30 Output Voltage Noise en µVP-P 10Hz to 10kHz 800 Line Regulation ∆VOUT/∆VIN VIN = 4.7V to 12.6V, TA = TMIN to TMAX 2 50 µV/V I Load Regulation ∆V SOURCE = 0mA to 1mA 0.6 1.8 OUT/∆IOUT mV/mA ISINK = 0mA to 1mA 1.75 18 T Quiescent Supply Current I A = +25°C 79 105 Q µA TA = TMIN to TMAX 130 Change in Supply Current vs. Change in Input Voltage ∆IQ/∆VIN VIN = 4.7V to 12.6V 1.7 6 µA/V
(VIN = 5.2V, IOUT = 0mA, TA = +25°C, unless otherwise noted.) (Note 1)
Supply Voltage VIN TA = TMIN to TMAX 5.2 12.6 V T Output Voltage V A = +25°C 4.950 5.000 5.050 OUT V TA = TMIN to TMAX 4.900 5.100 Output Voltage Temperature Coefficient TCVOUT TA = TMIN to TMAX 15 50 ppm/°C 0.1Hz to 10Hz 35 Output Voltage Noise en µVP-P 10Hz to 10kHz 900 Line Regulation ∆VOUT/∆VIN VIN = 5.2V to 12.6V, TA = TMIN to TMAX 1 50 µV/V I Load Regulation ∆V SOURCE = 0mA to 1mA 0.65 2 OUT/∆IOUT mV/mA ISINK = 0mA to 1mA 1.9 20 T Quiescent Supply Current I A = +25°C 80 110 Q µA TA = TMIN to TMAX 145 Change in Supply Current vs. Change in Input Voltage ∆IQ/∆VIN VIN = 5.2V to 12.6V 1.7 6 µA/V www.maximintegrated.com Maxim Integrated │ 3
