Datasheet DS4303 (Analog Devices) - 3
ОписаниеElectronically Programmable Voltage Reference
Страниц / Страница8 / 3 — Electronically Programmable. Voltage Reference. DS4303. NONVOLATILE …
Формат / Размер файлаPDF / 396 Кб
Electronically Programmable. Voltage Reference. DS4303. NONVOLATILE MEMORY CHARACTERISTICS. PARAMETER. SYMBOL. CONDITIONS. MIN. TYP. MAX
Electronically Programmable Voltage Reference DS4303 NONVOLATILE MEMORY CHARACTERISTICS PARAMETER SYMBOL CONDITIONS MIN TYP MAX
IC VREF SER 3.3V 0.03% SOT23-5. Series Voltage Reference IC 3.3V ±0.03% SOT-23-5. PMIC - Voltage Reference
Триема
DS4303R-U х микросхема
428 ₽
727GS
DS4303R-U+
Maxim
от 719 ₽
Рутоника
DS4303R-U+
Maxim
DS4303R-U+
(VCC = +2.4V to 3.6V, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
Programming Cycles +70°C (Note 8) 50,000 Cycles
Note 1:
All voltages referenced to ground.
Note 2:
Tracking accuracy is defined as VOUT - VIN after the DS4303 has completed self-adjustment.
Note 3:
Quantization refers to the size of the voltage steps used to track the input signal.
Note 4:
Settling time is the maximum amount of time VOUT requires to self-adjust. The settling time is determined by the following formula: ∆VOUT x tST.
Note 5:
EEPROM programming time is the hold time required after the DS4303 has completed self-adjustment before VIN or VCC can be removed or before ADJ can be toggled low once again.
Note 6:
Turn-on time is defined as the time required for VOUT to reach its specified accuracy after the required supply voltage is applied.
Note 7:
VOUT not loaded.
Note 8:
Guaranteed by design.
Typical Operating Characteristics
(VCC = 3.3V, TA = +25°C, unless otherwise noted.)
ACTIVE SUPPLY CURRENT ACTIVE SUPPLY CURRENT ACTIVE SUPPLY CURRENT vs. TEMPERATURE (VOUT = 0.3V) vs. TEMPERATURE (VOUT = 3.0V) vs. SUPPLY VOLTAGE
1.30 1.45 1.40 VCC = 3.6V 1.43 1.35 DS4303 toc01 1.25 DS4303 toc02 DS4303 toc03 1.41 V T CC = 3.6V A = +85°C VCC = 3.3V 1.30 1.39 1.20 TA = +25°C 1.37 1.25 TA = -40°C 1.15 VCC = 3.0V 1.35 1.20 1.33 1.15 1.10 SUPPLY CURRENT (mA) V V SUPPLY CURRENT (mA) 1.31 CC = 3.3V SUPPLY CURRENT (mA) CC = 2.4V 1.10 1.29 1.05 1.27 1.05 IL = 0mA IL = 0mA ADJ = VCC IL = 0mA ADJ = VCC 1.00 1.25 1.00 -40 -15 10 35 60 85 -40 -15 10 35 60 85 2.4 2.6 2.8 3.0 3.2 3.4 3.6 TEMPERATURE (°C) TEMPERATURE (°C) SUPPLY VOLTAGE (V)
_____________________________________________________________________ 3
