Datasheet MAX6190, MAX6191, MAX6192, MAX6193, MAX6194, MAX6195, MAX6198 (Analog Devices) - 5
ОписаниеPrecision, Micropower, Low-Dropout Voltage References
Страниц / Страница14 / 5 — MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage …
Формат / Размер файлаPDF / 264 Кб
MAX6190–MAX6195/MAX6198. Precision, Micropower,. Low-Dropout Voltage References. ELECTRICAL CHARACTERISTICS—MAX6193. PARAMETER
MAX6190–MAX6195/MAX6198 Precision, Micropower, Low-Dropout Voltage References ELECTRICAL CHARACTERISTICS—MAX6193 PARAMETER
14 предложений от 12 поставщиков
Опорный чип напряжения, V-Ref Precision 5V 0.5mA 8Pin SOIC N T/R
MAX6195CESA+T
Maxim
218 ₽
MAX6195CESA+T
Maxim
517 ₽
MAX6195CESA+T
ТаймЧипс
MAX6195CESAT
Maxim
(VIN = 5V, IOUT = 0nA, TA = TMIN to TMAX, unless otherwise noted. Typical values are at TA = +25°C.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS OUTPUT
MAX6193A 2.998 3.000 3.002 Output Voltage VOUT TA = +25°C MAX6193B 2.995 3.000 3.005 V MAX6193C 2.990 3.000 3.010 MAX6193A 2 5 Output-Voltage Temperature TCVOUT MAX6193B 4 10 ppm/°C Coefficient (Note 1) MAX6193C 8 25 ΔVOUT/ Line Regulation 2.5V ≤ VIN ≤ 12.6V 20 150 µV/V ΔVIN Sourcing: 0 ≤ I 0.14 0.60 ΔVOUT/ OUT ≤ 500µA Load Regulation µV/µA ΔIOUT Sinking: -500µA ≤ I 0.18 0.80 OUT ≤ 0 Dropout Voltage (Note 4) VIN - VOUT IOUT = 500µA 100 200 mV Short to GND 4 Short-Circuit Current ISC mA Short to IN 4 Temperature Hysteresis ΔVOUT/ 75 ppm (Note 2) cycle ΔVOUT/ ppm/ Long-Term Stability 1000hrs at +25°C 50 time 1000hrs
DYNAMIC
0.1Hz to 10Hz 75 µVP-P Noise Voltage eOUT 10Hz to 10kHz 150 µVRMS Ripple Rejection VOUT/VIN VIN = 5V ±100mV, f = 120Hz 80 dB Turn-On Settling Time tR To 0.1%, COUT = 50pF 100 µs Capacitive-Load Stability Range COUT (Note 3) 0 2.2 nF
INPUT
Supply Voltage Range VIN Guaranteed by line-regulation test VOUT + 0.2 12.6 V Quiescent Supply Current IIN 27 35 µA Change in Supply Current IIN/VIN (VOUT + 0.2V) ≤ VIN ≤ 12.6V 0.8 2 µA/V Maxim Integrated 5
