Datasheet MAX6133 (Analog Devices) - 3
Описание3ppm/°C, Low-Power, Low-Dropout Voltage Reference
Страниц / Страница13 / 3 — 3ppm/°C, Low-Power, Low-Dropout. Voltage Reference. MAX6133. ELECTRICAL …
Формат / Размер файлаPDF / 523 Кб
3ppm/°C, Low-Power, Low-Dropout. Voltage Reference. MAX6133. ELECTRICAL CHARACTERISTICS—MAX6133_30 (VOUT = 3.0000V). PARAMETER
3ppm/°C, Low-Power, Low-Dropout Voltage Reference MAX6133 ELECTRICAL CHARACTERISTICS—MAX6133_30 (VOUT = 3.0000V) PARAMETER
Опорный чип напряжения, V-Ref Precision 2.5V 15mA 8Pin SOIC N T/R
MAX6133BASA25+T
Maxim
147 ₽
727GS
MAX6133BASA25+T
Maxim
от 216 ₽
MAX6133BASA25+T
Maxim
491 ₽
SUV System
MAX6133BASA25+T
(VIN = 5V, CLOAD = 0.1µF, IOUT = 0, TA = TMIN to TMAX. Typical values are at TA = +25°C, unless otherwise noted.)
PARAMETER SYMBOL CONDITIONS MIN TYP MAX UNITS
A grade SO 2.9988 3.0000 3.0012 Output Voltage VOUT TA = +25°C B grade SO 2.9976 3.0000 3.0024 V µMAX 2.9982 3.0000 3.0018 A grade SO -0.04 +0.04 Output Voltage TA = +25°C B grade SO -0.08 +0.08 % Accuracy µMAX -0.06 +0.06 TA = -40°C to +85°C 1 3 A grade SO TA = -40°C to +125°C 4 7 Output Voltage TA = -40°C to +85°C 3 5 Temperature TCVOUT B grade SO ppm/°C TA = -40°C to +125°C 5 10 Coefficient (Note 1) TA = -40°C to +85°C 1 5 µMAX TA = -40°C to +125°C 2 7 Input Voltage Range VIN Inferred from line regulation 3.2 12.6 V Line Regulation ∆VOUT/∆VIN 3.2V ≤ VIN ≤ 12.6V 2 30 µV/V Load Regulation ∆VOUT/∆IOUT -100µA ≤ IOUT ≤ 15mA 0.003 0.06 mV/mA Dropout Voltage ∆VOUT = 0.1%, IOUT = 1mA 0.01 0.2 VDO V (Note 2) ∆VOUT = 0.1%, IOUT = 10mA 0.2 0.4 Quiescent Supply TA = +25°C 40 60 IIN µA Current TA = -40°C to +125°C 85 Output Short-Circuit Short to GND: VOUT = 0V 90 ISC mA Current Short to VIN: VOUT = VIN -2 0.1Hz ≤ f ≤ 10Hz 24 µVP-P Output Voltage Noise en 10Hz ≤ f ≤ 1kHz 15 µVRMS Turn-On Settling Time tON VOUT settles to ±0.01% of final value 600 µs Thermal Hysteresis 120 ppm (Note 3) SO 40 Long-Term Stability ∆t = 1000 hours ppm µMAX 145
_______________________________________________________________________________________ 3
