Datasheet BUF802 (Texas Instruments) - 7
Описание | Wide-Bandwidth, 2.3-nv/√Hz, High-Input Impedance Buffer |
Страниц / Страница | 38 / 7 — BUF802. www.ti.com. 6.6 Electrical Characteristics: Low Quiescent Current … |
Формат / Размер файла | PDF / 2.1 Мб |
Язык документа | английский |
BUF802. www.ti.com. 6.6 Electrical Characteristics: Low Quiescent Current Mode. PARAMETER. Test Condition. MIN. TYP. MAX. UNIT
29 предложений от 10 поставщиков WIDE-BANDWIDTH, 2.3-NV/HZ, JFET / J-FET Amplifier 1 Circuit Push-Pull 16-VQFN (3x3) |
| BUF802IRGTR Texas Instruments | от 92 ₽ | |
| BUF802IRGTR Texas Instruments | 408 ₽ | |
| BUF802IRGTR Texas Instruments | по запросу | |
BUF802 www.ti.com
SBOS998C – JUNE 2021 – REVISED MARCH 2022
at TA = 25°C, VS = ±6 V, RL = 100 Ω || 400 fF. RS = 25 Ω, VOCM = 0 V (mid-supply), CLH and CLL tied to VS+ and VS– respectively, Low Quiescent Current Mode unless otherwise specified (R_Bias = 35.7 kΩ)
PARAMETER Test Condition MIN TYP MAX UNIT AC PERFORMANCE
SSBW Small-Signal Bandwidth VOUT = 100 mVPP 2.6 VOUT = 1 VPP 2 LSBW Large-Signal Bandwidth VOUT = 2 VPP 0.7 GHz Bandwidth for 0.1 dB flatness 0.45 VOUT = 1 VPP Bandwidth for -1 dB flatness 1.4 SR Slew rate VOUT = 1.2-V step, VIN-SR = 13000 V/µs 5500 V/µs VOUT = 1.2-V step (10% to 90%) 0.3 Rise and fall time ns VOUT = 0.25-V step (10% to 90%) 0.16 Settling time to 0.1% 1.4 VOUT = 1.2-V step, VIN-SR = 13000 V/µs ns Settling time to 1% 0.8 1/f corner 10 kHz en Voltage noise f = 100 MHz 2.2 nV/√Hz in Current noise f = 10 kHz 1.5 pA/√Hz VOUT = 2 VPP f = 500 MHz –35/–32 HD2/HD3 Harmonic distortion f = 100 MHz –80/–77 dBc VOUT = 1 VPP f = 500 MHz –56/–54
DC PERFORMANCE
RL = 200 Ω 0.96 0.975 0.99 VOUT = ± 0.5 V RL = 100 Ω 0.95 0.963 0.98 G DC Gain V/V V R OUT = ± 0.5 V ,TA = –40℃ L = 200 Ω 0.96 0.99 to 85℃ RL = 100 Ω 0.95 0.98
INPUT
CLH Clamping Time Time taken to clamp VOUT to VCLH during overdrive 0.3 nsec CLL Clamping Time Time taken to clamp VOUT to VCLL during overdrive 0.7
OUTPUT
ZO Output impedance f = 100 MHz 1.2 Ω
POWER SUPPLY
VS Operating voltage range ±4.5 ±6.5 V 21 24 IQ Quiescent current IOUT = 0 (R_bias = 35.7 kΩ) mA TA = –40℃ to 85℃ 22 Copyright © 2022 Texas Instruments Incorporated Submit Document Feedback 7 Product Folder Links: BUF802 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: Wide Bandwidth Mode 6.6 Electrical Characteristics: Low Quiescent Current Mode 6.7 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Input and Output Over-Voltage Clamp 8.3.2 Adjustable Quiescent Current 8.3.3 ESD Structure 8.4 Device Functional Modes 8.4.1 Buffer Mode (BF Mode) 8.4.2 Composite Loop Mode (CL Mode) 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Oscilloscope Front-End Amplifier Design 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curves 9.2.2 Transforming a Wide-Bandwidth, 50 Ω Input Signal Chain to High-Input Impedance 9.2.2.1 Detailed Design Results 9.2.2.2 Application Curves 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Receiving Notification of Documentation Updates 12.3 Support Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
