Datasheet BUF802 (Texas Instruments) - 8
ОписаниеWide-Bandwidth, 2.3-nv/√Hz, High-Input Impedance Buffer
Страниц / Страница38 / 8 — BUF802. www.ti.com. 6.7 Typical Characteristics. Figure 6-1. Frequency …
Формат / Размер файлаPDF / 2.1 Мб
BUF802. www.ti.com. 6.7 Typical Characteristics. Figure 6-1. Frequency Response vs Output Voltage
BUF802 www.ti.com 6.7 Typical Characteristics Figure 6-1 Frequency Response vs Output Voltage
29 предложений от 9 поставщиков
WIDE-BANDWIDTH, 2.3-NV/HZ, JFET / J-FET Amplifier 1 Circuit Push-Pull 16-VQFN (3x3)
Зенер
Россия и страны ТС
BUF802IRGTR
от 320 ₽
BUF802IRGTR
539 ₽
Эиком
BUF802IRGTR
от 813 ₽
BUF802IRGTR
BUF802
SBOS998C – JUNE 2021 – REVISED MARCH 2022
At TA = 25°C, VS = ±6 V, RL = 100 Ω || 400 fF, RS = 25 Ω, VOCM = 0 V (mid-supply), VOUT = 1 VPP, CLH and CLL tied to VS+ and VS- respectively, Wide Bandwidth Mode unless otherwise specified (R_Bias = 17.8 kΩ). 3 3 0 0 -3 -3 n (dB) n (dB) Gai -6 Gai -6 V V -9 OUT = 20 mVPP OUT = 20 mVPP V -9 OUT = 100 mVPP VOUT = 100 mVPP VOUT = 1 VPP VOUT = 1 VPP VOUT = 2 VPP VOUT = 2 VPP -12 -12 100M 1G 10G 100M 1G 10G Frequency (Hz) Frequency (Hz) Wide Bandwidth Mode Low Quiescent Current Mode
Figure 6-1. Frequency Response vs Output Voltage Figure 6-2. Frequency Response vs Output Voltage
0 3 VOUT = 20 mVPP VOUT = 100 mVPP -0.1 VOUT = 1 VPP 0 -0.2 -3 n (dB) -0.3 n (dB) Gai Gai -6 -0.4 -0.5 -9 VS = 4.5 V VS = 5 V VS = 6 V -0.6 -12 1M 10M 100M 1G 10G 100M 1G 10G Frequency (Hz) Frequency (Hz) Wide Bandwidth Mode .
Figure 6-3. Frequency Response vs Output Voltage, Figure 6-4. Frequency Response vs Supply Voltage 0.1 dB Flatness
3 3 0 0 -3 -3 n (db) n (dB) Gai -6 Gai -6 R -9 L = 100 R -9 L = 200 R_Bias = 17.8 k RL = 1 k R_Bias = 35.7 k RL = 2 k R_Bias = 100 k -12 -12 100M 1G 10G 100M 1G 10G Frequency (Hz) Frequency (Hz) . .
Figure 6-5. Frequency Response vs Output Load Figure 6-6. Frequency Response vs R_Bias Resistance
8 Submit Document Feedback Copyright © 2022 Texas Instruments Incorporated Product Folder Links: BUF802 Document Outline 1 Features 2 Applications 3 Description Table of Contents 4 Revision History 5 Pin Configuration and Functions 6 Specifications 6.1 Absolute Maximum Ratings 6.2 ESD Ratings 6.3 Recommended Operating Conditions 6.4 Thermal Information 6.5 Electrical Characteristics: Wide Bandwidth Mode 6.6 Electrical Characteristics: Low Quiescent Current Mode 6.7 Typical Characteristics 7 Parameter Measurement Information 8 Detailed Description 8.1 Overview 8.2 Functional Block Diagram 8.3 Feature Description 8.3.1 Input and Output Over-Voltage Clamp 8.3.2 Adjustable Quiescent Current 8.3.3 ESD Structure 8.4 Device Functional Modes 8.4.1 Buffer Mode (BF Mode) 8.4.2 Composite Loop Mode (CL Mode) 9 Application and Implementation 9.1 Application Information 9.2 Typical Application 9.2.1 Oscilloscope Front-End Amplifier Design 9.2.1.1 Design Requirements 9.2.1.2 Detailed Design Procedure 9.2.1.3 Application Curves 9.2.2 Transforming a Wide-Bandwidth, 50 Ω Input Signal Chain to High-Input Impedance 9.2.2.1 Detailed Design Results 9.2.2.2 Application Curves 10 Power Supply Recommendations 11 Layout 11.1 Layout Guidelines 11.2 Layout Example 12 Device and Documentation Support 12.1 Documentation Support 12.1.1 Related Documentation 12.2 Receiving Notification of Documentation Updates 12.3 Support Resources 12.4 Trademarks 12.5 Electrostatic Discharge Caution 12.6 Glossary 13 Mechanical, Packaging, and Orderable Information
