Datasheet SG-8002 (Epson) - 4
ПроизводительEpson
ОписаниеCrystal Oscillator Programmable
Страниц / Страница6 / 4 — SG-8002 Series Outline of specifications. Supply. Operating. Output load. …
Формат / Размер файлаPDF / 700 Кб
SG-8002 Series Outline of specifications. Supply. Operating. Output load. Model. volt-. Symmetry. Output rise time /. temperature
SG-8002 Series Outline of specifications Supply Operating Output load Model volt- Symmetry Output rise time / temperature
Элитан
SG-8002CE-33.0000M-SCM722 ₽
SG-8002CE
SG-8002JA
Crystal oscillator
SG-8002 Series Outline of specifications Supply Operating Output load Model volt- Symmetry Output rise time / temperature condition age Output fall time
40 % to 60 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤125 MHz) -20 °C to +70 °C 2.0 ns Max. (0.8 V to 2.0 V,L_TTL=Max.) PT/ST 5TTL+15pF 45 % to 55 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤66.7 MHz) 4.0 ns Max. (0.4 V to 2.4 V,L_TTL=Max.) 4.5 V to -40 °C to +85 °C 45 % to 55 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤27.0 MHz) 5.5 V 15 pF (f0≤125 MHz) 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤125 MHz) -20 °C to +70 °C PH/SH 25 pF (f0≤100 MHz) 45 % to 55 % (50 % VCC, L_CMOS=25 pF, f0≤66.7 MHz) 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.)
SG-8002CE
-40 °C to +85 °C 25 pF (f0≤27 MHz) 45 % to 55 % (50 % VCC, L_CMOS=25 pF, f0≤27.0 MHz) 3.0 V to 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤125 MHz) 3.6 V 45 % to 55 % (50 % VCC, L_CMOS=15 pF, f0≤40 MHz) PC/SC -40 °C to +85 °C 15 pF 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.) 2.7 V to 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤66.7 MHz) 3.6 V 40 % to 60 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤125 MHz) 5TTL+15pF (f0≤125 MHz) -20 °C to +70 °C ↑ (1.4 V, L_CMOS=25 pF, f0≤66.7 MHz) 25 pF (f0≤66.7 MHz) 2.0 ns Max. (0.8 V to 2.0 V,L_CMOS or L_TTL=Max.) PT/ST 45 % to 55 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤66.7 MHz) 4.0 ns Max. (0.4 V to 2.4 V,L_CMOS or L_TTL=Max.) 5 TTL+15 pF (f0≤40 MHz) 40 % to 60 % (1.4 V, L_CMOS=15 pF, f0≤55.0 MHz) -40 °C to +85 °C
SG-8002CA
4.5 V to 15 pF (f0≤55 MHz) 45 % to 55 % (1.4 V, L_TTL=5 TTL+15 pF, f0≤40.0 MHz) 5.5 V 40 % to 60 % (50 % VCC, L_CMOS=25 pF, f0≤125 MHz) 25 pF (f0≤125 MHz)
SG-8002JA
-20 °C to +70 °C ↑ (50 % VCC, L_CMOS=50 pF, f0≤66.7 MHz) 50 pF (f0≤66.7 MHz) 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS≤25pF) PH/SH 45 % to 55 % (50 % VCC, L_CMOS=25 pF, f0≤66.7 MHz) 4.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.)
SG-8002DC
15 pF (f0≤55 MHz) 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤55.0 MHz) -40 °C to +85 °C 25 pF (f0≤40 MHz) 45 % to 55 % (50 % VCC, L_MOS=25 pF, f0≤40.0 MHz) 3.0 V to 15 pF 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤125 MHz) 3.6 V 30 pF (f0≤40 MHz) 45 % to 55 % (50 % VCC, L_CMOS=30 pF, f0≤40 MHz) 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS≤15pF) PC/SC -40 °C to +85 °C 2.7 V to 4.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.) 15 pF 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤66.7 MHz) 3.6 V 40 % to 60 % (1.4 V,L_CMOS=15 pF, f0≤125 MHz) 5TTL+15 pF (f0≤90 MHz) ↑ (1.4 V,L_TTL=5 TTL+15 pF, f0≤90.0 MHz) 2.0 ns Max. (0.8 V to 2.0 V,L_CMOS or L_TTL=Max.) PT/ST 15 pF (f0≤125 MHz) ↑ (1.4 V,L_CMOS=25 pF, f0≤66.7 MHz) 4.0 ns Max. (0.4 V to 2.4 V,L_CMOS or L_TTL=Max.) 25 pF (f0≤66.7 MHz) 4.5 V to 45 % to 55 % (1.4 V,L_TTL=5 TTL+15 pF, f0≤66.7 MHz) -20 °C to +70 °C 5.5 V 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤125 MHz) 15 pF (f0≤125 MHz) ↑ (50 % VCC, L_CMOS=25 pF, f0≤90 MHz) 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS≤25pF)
SG-8002JC
PH/SH 25 pF (f0≤90 MHz) ↑ (50 % VCC, L_CMOS=50 pF, f0≤50 MHz) 4.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.) 50 pF (f0≤66.7 MHz) 45 % to 55 % (50 % VCC, L_CMOS=25 pF, f0≤66.7 MHz) 3.0 V to 15 pF 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤125 MHz) 3.6 V 30 pF (f0≤40 MHz) 45 % to 55 % (50 % VCC, L_CMOS=30 pF, f0≤40 MHz) 3.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS≤15pF) PC/SC -20 °C to +70 °C 2.7 V to 4.0 ns Max. (20 % VCC to 80 % VCC,L_CMOS=Max.) 15 pF 40 % to 60 % (50 % VCC, L_CMOS=15 pF, f0≤66.7 MHz) 3.6 V Product Name SG-8002 CE 125.000000MHz S C C ⑤Supply voltage ⑥Frequency tolerance
Operating temperature (Standard form) ① ② ③ ④⑤⑥ T,H 5.0 V Typ. B ±50 × 10-6 / -20 to +70°C ①Model ②Package type ③Frequency C 3.0 / 3.3 V Typ. C ±100 × 10-6 / -20 to +70°C ④Function (P: Output enable, S:Standby) M ±100 × 10-6 / -40 to +85°C ⑤Supply voltage ⑥Frequency tolerance
Operating temperature *As per table below. ►
TABLE OF FREQUENCY RANGE*
Model(①, ②) Function, Supply voltage(④, ⑤) Supply voltage(⑤) Frequency(③) Frequency tolerance / Operating Temperature(⑥) PT/ ST 1.0 MHz to 125 MHz B,C 4.5 V to 5.5 V PH/ SH 1.0 MHz to 27 MHz M
SG-8002CE
3.0 V to 3.6 V 1.0 MHz to 125 MHz PC/SC B,C,M 2.7 V to 3.6 V 1.0 MHz to 66.7 MHz PT/ ST 1.0 MHz to 125 MHz B,C
SG-8002CA
4.5 V to 5.5 V PH/ SH 1.0 MHz to 55 MHz M
SG-8002JA
SG-8002DC
PC/ SC B,C,M 2.7 V to 3.6 V 1.0 MHz to 66.7 MHz PT/ ST 4.5 V to 5.5 V 1.0 MHz to 125 MHz B,C PH/ SH
SG-8002JC
3.0 V to 3.6 V 1.0 MHz to 125 MHz PC/ SC B,C 2.7 V to 3.6 V 1.0 MHz to 66.7 MHz Document Outline SG-8002series_E187.pdf QMEMS_E152
