Datasheet SGL13, SGL41 (Vishay) - 2
ПроизводительVishay
ОписаниеSurface Mount Schottky Barrier Rectifier
Страниц / Страница5 / 2 — ELECTRICAL CHARACTERISTICS. THERMAL CHARACTERISTICS. ORDERING INFORMATION
Формат / Размер файлаPDF / 86 Кб
ELECTRICAL CHARACTERISTICS THERMAL CHARACTERISTICS ORDERING INFORMATION
38 предложений от 16 поставщиков
SGL41-60-E3/96
от 10 ₽
SGL41-60-E3/96
16 ₽
SGL41-60-E3/96
28 ₽
SGL41-60-E3/96
63 ₽
BYM13-xx, SGL41-xx www.vishay.com Vishay General Semiconductor
(TA = 25 °C unless otherwise noted) BYM13-20 BYM13-30 BYM13-40 BYM13-50 BYM13-60 PARAMETER TEST CONDITIONS SYMBOL UNIT SGL41-20 SGL41-30 SGL41-40 SGL41-50 SGL41-60 Maximum instantaneous forward voltage (1) 1.0 A VF 0.50 0.50 0.50 0.70 0.70 V Maximum reverse TA = 25 °C 0.5 current at rated DC IR mA blocking voltage (1) TA = 100 °C 10 5.0 Typical junction 4.0 V, 1.0 MHz C capacitance J 110 80 pF Note (1) Pulse test: 300 μs pulse width, 1 % duty cycle
(TA = 25 °C unless otherwise noted) BYM13-20 BYM13-30 BYM13-40 BYM13-50 BYM13-60 PARAMETER SYMBOL UNIT SGL41-20 SGL41-30 SGL41-40 SGL41-50 SGL41-60 RθJA 75 Maximum thermal resistance (1) °C/W RθJT 30 Note (1) Thermal resistance junction to terminal, 0.24" x 0.24" (6.0 mm x 6.0 mm) copper pads to each terminal
(Example) PREFERRED P/N UNIT WEIGHT (g) PREFERRED PACKAGE CODE BASE QUANTITY DELIVERY MODE SGL41-40-E3/96 0.137 96 1500 7" diameter plastic tape and reel SGL41-40-E3/97 0.137 97 5000 13" diameter plastic tape and reel BYM13-40-E3/96 0.137 96 1500 7" diameter plastic tape and reel BYM13-40-E3/97 0.137 97 5000 13" diameter plastic tape and reel SGL41-40HE3_A/H (1) 0.137 H 1500 7" diameter plastic tape and reel SGL41-40HE3_A/I (1) 0.137 I 5000 13" diameter plastic tape and reel BYM13-40HE3_A/H (1) 0.137 H 1500 7" diameter plastic tape and reel BYM13-40HE3_A/I (1) 0.137 I 5000 13" diameter plastic tape and reel Note (1) AEC-Q101 qualified Reivision: 01-Sep-2021 2 Document Number: 88548 For technical questions within your region: DiodesAmericas@vishay.com, DiodesAsia@vishay.com, DiodesEurope@vishay.com THIS DOCUMENT IS SUBJECT TO CHANGE WITHOUT NOTICE. THE PRODUCTS DESCRIBED HEREIN AND THIS DOCUMENT ARE SUBJECT TO SPECIFIC DISCLAIMERS, SET FORTH AT www.vishay.com/doc?91000
