Datasheet AZ9431Q (Diodes) - 8
ПроизводительDiodes
ОписаниеAutomotive Compliant 1.24v Adjustable Precision Shunt Regulator
Страниц / Страница9 / 8 — AZ9431Q. Package Outline Dimensions. SOT23. Dim. Min. Max. Typ. All …
Формат / Размер файлаPDF / 897 Кб
AZ9431Q. Package Outline Dimensions. SOT23. Dim. Min. Max. Typ. All Dimensions in mm. Suggested Pad Layout. Dimensions Value (in mm)
AZ9431Q Package Outline Dimensions SOT23 Dim Min Max Typ All Dimensions in mm Suggested Pad Layout Dimensions Value (in mm)
Please see http://www.diodes.com/package-outlines.html for the latest version.
SOT23
Al 7° H
SOT23
GAUGE PLANE 0.25
Dim Min Max Typ
J
A
0.37 0.51 0.40 K1 K
B
1.20 1.40 1.30
C
2.30 2.50 2.40 a
D
0.89 1.03 0.915 A M
F
0.45 0.60 0.535 L L1
G
1.78 2.05 1.83
H
2.80 3.00 2.90
J
0.013 0.10 0.05
K
0.890 1.00 0.975 C B
K1
0.903 1.10 1.025
L
0.45 0.61 0.55
L1
0.25 0.55 0.40
M
0.085 0.150 0.110
a
0° 8° -- D
F G
SOT23 Dimensions Value (in mm) C
2.0 Y
X
0.8
X1
1.35
Y
0.9 Y1 C
Y1
2.9 X X1 Note: 8. The suggested land pattern dimensions have been provided for reference only, as actual pad layouts may vary depending on application. These dimensions may be modified based on user equipment capability or fabrication criteria. A more robust pattern may be desired for wave soldering and is calculated by adding 0.2 mm to the ‘Z’ dimension. For further information, please reference document IPC-7351A, Naming Convention for Standard SMT Land Patterns, and for International grid details, please see document IEC, Publication 97.
Mechanical Data
Moisture Sensitivity: Level 1 per J-STD-020 Terminals: Finish – Matte Tin Plated Leads, Solderable per MIL-STD-202, Method 208 Weight: 0.009 grams (Approximate) AZ9431Q 8 of 9 January 2022 Document number: DS40953 Rev. 2 - 2
www.diodes.com
© Diodes Incorporated
