Datasheet TLV431 (Diodes) - 2
ПроизводительDiodes
Описание1.24v Cost Effective Shunt Regulator
Страниц / Страница17 / 2 — TLV431. Typical Application Circuit. Absolute Maximum Ratings. Symbol. …
Формат / Размер файлаPDF / 1.6 Мб
TLV431. Typical Application Circuit. Absolute Maximum Ratings. Symbol. Parameter. Rating. Unit. ESD Susceptibility
TLV431 Typical Application Circuit Absolute Maximum Ratings Symbol Parameter Rating Unit ESD Susceptibility
39 предложений от 14 поставщиков
Интегральные микросхемы Микросхемы управления электропитанием - Опорное напряжение
TLV431AQFTA
Diodes
7.77 ₽
TLV431AQFTA
Diodes
8.49 ₽
Microfind
TLV431AQFTA
Diodes
15 ₽
Hi-Tech Circuit Group
TLV431AQFTA
Diodes
Secondary side 3.3 V regulated supply Optocoupler IF Primary side controller R3 R1 TLV431 R2 GND
(@TA = +25°C, unless otherwise specified.)
VKA Cathode Voltage 20 V IKA Continuous Cathode Current -20 to +20 mA IREF Reference Input Current Range -0.05 to +3 mA
ESD Susceptibility
(Note 4) HBM Human Body Model 4 kV MM Machine Model 400 V CDM Charged Device Model 1 kV Note: 4. Semiconductor devices are ESD sensitive and can be damaged by exposure to ESD events. Suitable ESD precautions should be taken when handling and transporting these devices.
Operating Junction Temperature (Note 5) -40 to +150 °C Storage Temperature (Note 5) -65 to +150 °C Note: 5. Operation above the absolute maximum rating can cause device failure. Operation at the absolute maximum ratings, for extended periods, can reduce device reliability. Unless otherwise stated voltages specified are relative to the ANODE pin. These are stress ratings only. Operation outside the absolute maximum ratings can cause device failure.
Recommended Operating Conditions
Symbol Parameter Min Max Units
VKA Cathode Voltage VREF 18 V IKA Cathode Current 0.1 15 mA TA Operating Ambient Temperature Range -40 +125 °C
Package Thermal Data PDIS Package
JA TA = +25°C, TJ = +150°C
SOT23 380°C/W 330mW SOT25 250°C/W 500mW SC70-6 (SOT363) 380°C/W 330mW TLV431 2 of 17 March 2024 Document number: DS32088 Rev. 9 - 2
www.diodes.com
© 2024 Copyright Diodes Incorporated. All Rights Reserved.
